I recently apt updated/upgraded - it was working a week ago when I tried it.
- Raspberry Pi 4
- Also running Apache2
- No docker containers
Accessing through DDNS domain, web interface accepts my password. But after that the circle on the right just spins.
https://tricorder.pi-hole.net/6M3Cm8j4/
This is a permission issue.
You want to use port 84:
[webserver]
domain = "pi.hole"
acl = ""
port = "8080o,8443os,[::]:8080o,[::]:84"
But your OS is not allowing to bind to port 84:
[2025-09-26 16:44:45.732 PDT 1956856] cannot bind to IPv6 [::]:84: 13 (Permission denied)
[2025-09-26 16:44:45.732 PDT 1956856] Failed to setup server ports
I think this is a typo. Try this command to change the ports:
sudo pihole-FTL --config webserver.port '8080o,8443os,[::]:8080o,[::]:8443os'
