Ftl dns data tables warning
reply field showing data
error message with unknown parameter
Debug Token: s5fdbsb93p
Hello just installed ftldns beta
get error message of unknown parameter . and no data . also running cloudfare and openvpn server on pi . tried reboot and flush logs but no solution
According to your screenshot your checkout was incomplete (it shows FTLDNS for core and web, but not for FTL itself!). Please try again and show us the instructions you used.
please try again what ?
these instructions use to upgrade
echo "FTLDNS" | sudo tee /etc/pihole/ftlbranch
pihole checkout core FTLDNS
pihole checkout web FTLDNS
and these for the cloudfare problem
sudo iptables -A INPUT -i eth0 -p tcp --destination-port 53 -j REJECT
sudo iptables -A INPUT -i eth0 -p udp --destination-port 53 -j ACCEPT
which info do you need further
problem solved with update and pihole repair twice . post can be closed
