Error: Unable to get latest release location from GitHub
[✗] FTL Engine not installed
[✓] man pages installed and datab
* Pinging 192.168.1.1...
** [ DIAGNOSING ]: Name resolution (IPv4) using a random blocked domain and a known ad-serving domain
[✗] Failed to resolve via localhost (127.0.0.1)
[✗] Failed to resolve via Pi-hole (192.168.1.3)
[✓] doubleclick.com is 172.217.9.78 via a remote, public DNS server (8.8.8.8)
Run the following command from the Pi linux terminal and paste results. This will query your stats.
echo ">stats" | nc localhost 4711
Also run this command, paste results and verify that the time matches your local time. DNSSEC needs an accurate time to work properly.
