jdrch
1
Dashboard should show hundreds of thousands of domains on blocklist when Pi-Hole is enabled
Dashboard shows 0 domains on blocklist when Pi-Hole is enabled
nfh87mb2xh
What are the total domains blocked shown in the console output when you run pihole -g
on the Pi-hole node?
You're running both dev and master versions of Pi-hole components. Run pihole checkout master
to get back on track for v4.3
jdrch
5
Thanks, that worked! Unfortunately it also blew my blocklists away, so I'm gonna have to rebuild them. Thanks again.
system
Closed
6
