Hi all,
my problem is very similar to this one this one - exept my pi hole runs without the built-in DHCP-Server.
So the problem is i cant get the ipv6 reverse lookup running (ipv4 works fine). In the Dashboard's Top Clients i only get to see ipv6-adresses which makes it impossible to match users and machines.
I tried several recommendations .. with/without ULAs, with different upstream DNS-Server, conditional forwarding etc.
Current setup looks as following :
- DHCPv6 on fritzbox enabled
- Fritzbox delivers the pi hole's v4+v6 adress via DHCPv6
- "Never forward non-FQDNs" and "Never forward reverse lookups for private IP ranges" disabled
- Fritzbox is configured as ipv4 and ipv6 Upstream
- "fritz.box" Domain is configured as rebound protection
Forward resolution works perfectly.
root@raspberrypi:~# dig -t AAAA desktop.fritz.box +short @192.168.1.1
2001:4dd6:5cee:0:2d83:f359:a5ff:f260
But reverse doesn't work at all.
; <<>> DiG 9.10.3-P4-Raspbian <<>> -x 2001:4dd6:5cee:0:2d83:f359:a5ff:f260 @192.168.1.1
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 55641
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 0
;0.6.2.f.f.f.5.a.9.5.3.f.3.8.d.2.0.0.0.0.e.e.c.5.6.d.d.4.1.0.0.2.ip6.arpa. IN PTR
;; AUTHORITY SECTION:
0.0.0.0.e.e.c.5.6.d.d.4.1.0.0.2.ip6.arpa. 9 IN SOA fritz.box. admin.fritz.box. 1559594332 21600 1800 43200 10
;; Query time: 1 msec
;; SERVER: 192.168.1.1#53(192.168.1.1)
;; WHEN: Mon Jun 03 21:38:52 BST 2019
;; MSG SIZE rcvd: 150
It almost seems like this is not completly a pi hole problem.. but kind of related to it.
Do you have any information on this? Should the fritzbox deliver the ipv6's reverse resolution for native and ULA-adresses. Do i have some kind of misconception?
Thank you in advance!
Reverse resolution of ipv6 adresses .. for example in Top Clients list.
Only ipv6 adresses, instead of hostnames. ipv4 works fine.
ye1va4xlas
