Fresh install on Ubuntu 20.04.1 LTS failed at DNS resolution
fresh install of pihole on an Ubuntu 20.04.1 LTS (HYPERV VM) with the command
curl -sSL https://install.pi-hole.net | bash
Pihole should be installed and DNS resolution should be ok.
the installation silently failed after displaying those lines:
  [✓] Deleting existing list cache
  [✗] DNS service is not running
  [✓] Restarting DNS server
  [✗] DNS resolution is not available
no more DNS resolution server wide.
when trying to debug why DNS resolution is broken, I've tried to : cat /etc/resolv.conf
which stated that my actual DNS is 127.0.0.53 ???
# This file is managed by man:systemd-resolved(8). Do not edit.
# This is a dynamic resolv.conf file for connecting local clients to the
# internal DNS stub resolver of systemd-resolved. This file lists all
# configured search domains.
# Run "resolvectl status" to see details about the uplink DNS servers
# currently in use.
# Third party programs must not access this file directly, but only through the
# symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a different way,
# replace this symlink by a static file or a different symlink.
# See man:systemd-resolved.service(8) for details about the supported modes of
# operation for /etc/resolv.conf.
nameserver 127.0.0.53
options edns0 trust-ad
When inspecting the DNS servers with resolvectl status
Global
       LLMNR setting: no
MulticastDNS setting: no
  DNSOverTLS setting: no
      DNSSEC setting: no
    DNSSEC supported: no
          DNSSEC NTA: 10.in-addr.arpa
                      16.172.in-addr.arpa
                      168.192.in-addr.arpa
                      17.172.in-addr.arpa
                      18.172.in-addr.arpa
                      19.172.in-addr.arpa
                      20.172.in-addr.arpa
                      21.172.in-addr.arpa
                      22.172.in-addr.arpa
                      23.172.in-addr.arpa
                      24.172.in-addr.arpa
                      25.172.in-addr.arpa
                      26.172.in-addr.arpa
                      27.172.in-addr.arpa
                      28.172.in-addr.arpa
                      29.172.in-addr.arpa
                      30.172.in-addr.arpa
                      31.172.in-addr.arpa
                      corp
                      d.f.ip6.arpa
                      home
                      internal
                      intranet
                      lan
                      local
                      private
                      test
Link 3 (docker0)
      Current Scopes: none
DefaultRoute setting: no
       LLMNR setting: yes
      DNSSEC setting: no
Link 2 (eth0)
      Current Scopes: DNS
DefaultRoute setting: yes
       LLMNR setting: yes
      DNSSEC setting: no
         DNS Servers: 192.168.0.254
                      80.67.169.12
                      80.67.169.40
                      fd0f:ee:b0::1
I've managed to access pihole's interface after running sudo pihole -a -p
Installation should state that everything is correctly installed and working and internet with DNS resolution is still up and ok
Full debug log removed by moderator and made private.
This from your debug log:
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
   id    timestamp            type                  message                                                       blob1                 blob2                 blob3                 blob4                 blob5
   1     2021-01-08 13:57:21  DNSMASQ_CONFIG        cannot access /etc/dnsmasq.d/lxd: No such file or directory
Please post the output of these commands from the Pi terminal:
pihole-FTL dnsmasq-test
sudo grep -v '#\|^$' -R /etc/dnsmasq.*
modo@modo:~$ pihole-FTL dnsmasq-test
dnsmasq: cannot access /etc/dnsmasq.d/lxd: No such file or directory
modo@modo:~$ sudo grep -v '#\|^$' -R /etc/dnsmasq.*
sudo: unable to resolve host modo: Temporary failure in name resolution
[sudo] password for modo:
/etc/dnsmasq.conf:conf-dir=/etc/dnsmasq.d
/etc/dnsmasq.conf.old:conf-dir=/etc/dnsmasq.d
grep: /etc/dnsmasq.d/lxd: No such file or directory
/etc/dnsmasq.d/01-pihole.conf:addn-hosts=/etc/pihole/local.list
/etc/dnsmasq.d/01-pihole.conf:addn-hosts=/etc/pihole/custom.list
/etc/dnsmasq.d/01-pihole.conf:localise-queries
/etc/dnsmasq.d/01-pihole.conf:no-resolv
/etc/dnsmasq.d/01-pihole.conf:cache-size=10000
/etc/dnsmasq.d/01-pihole.conf:log-queries
/etc/dnsmasq.d/01-pihole.conf:log-facility=/var/log/pihole.log
/etc/dnsmasq.d/01-pihole.conf:local-ttl=2
/etc/dnsmasq.d/01-pihole.conf:log-async
/etc/dnsmasq.d/01-pihole.conf:server=1.1.1.1
/etc/dnsmasq.d/01-pihole.conf:server=1.0.0.1
/etc/dnsmasq.d/01-pihole.conf:interface=eth0
/etc/dnsmasq.d/01-pihole.conf:server=/use-application-dns.net/
I've checked with:
modo@modo:~$ ll /etc/dnsmasq.d/lxd
lrwxrwxrwx 1 root root 28 Apr 26  2018 /etc/dnsmasq.d/lxd -> /etc/dnsmasq.d-available/lxd
but there is no /etc/dnsmasq.d-available/ directory available
Should I remove the symbolic link ?
Did I miss something before trying to install pihole ?
i've managed to foudn someone with the same problem :
all i did to solve the problem is removing the link
