Fresh install has web GUI DataTables errors
The issue I am facing:
When accessing Local DNS Records (and some other pages) I get the error "DataTables warning: table id=customDNSTable - Invalid JSON response. For more information about this error, please see 1. Warning: Invalid JSON response"
Details about my system:
Fresh install on an Ubuntu 22.04LTS VM running on Proxmox
Nothing
There are multiple posts about this problem in previous versions, but in all cases it was an upgrade from even earlier versions and solved with the flushing of the cache of the browsers.
In my case that point is mute to begin with; there is no cache to flush since it is a fresh install.
What do I have to do to fix this bug in the web interface?
It's not like I have the time to go into the source, like I would if I got this error in my own web applications.
It is also very likely that the bug is related to being unable to add a local DNS entry (unknown error, no explanation).
Tools > Generate Debug Log
https://tricorder.pi-hole.net/UhaarUnb/
