I wanted to set up a new Pi-hole. So I took a new RasPi 4b with Debian 11 and ran "curl -sSL https://install.pi-hole.net | PIHOLE_SKIP_OS_CHECK=true sudo -E bash".
[Installation should run until the end.]
[Installation stops after "(i) Restarting lighttpd service...".
So I received no webadmin password and also cannot access the webadmin itself.]
" You can disable this check by setting an environment variable named PIHOLE_SKIP_OS_CHECK to true , however Pi-hole may have issues installing. If you choose to use this environment variable, please use the Community Help topic on Discourse to troubleshoot any installation issues you may (or may not!) have."
Does this count?
Or is it really the only solution that it won't work right now with a fresh install?
For Pi-hole versions prior to Pi-hole FTL v5.9, Web v5.6 and Core v5.4 (which were released today), the following commands will install Pi-hole on Bullseye:
