Fresh install, DNS/FTP not running/offline
I felt adventurous the other day and based on all the notices at the bottom of the page of new version of pihole and its components, I choose to update. I ran into issues similar to others, FTL issues. I followed steps listed in numerous threads here, none of which worked for me.
I got my backup of the pihole settings and decided to start all over. I reinstalled Raspbian Jessie, booted to it, uninstalled libreoffice, wolfram, applications like that which I don't use. Yes, I had desktop version local, so I decided to use it. I ran apt-get update, apt-upgrade, then did a "sudo curl -sSL https://install.pi-hole.net | bash"
I did not notice any alerts during the install.
both the jessie apt-get update/upgrade and the pihole install were performed on March 25. This was an updated Jessie OS.
I log into the webpage and now it is worse that before, not it says both "DNS service not running" and "FTL offline". Yesterday it only said FTL offline.
No amount of clicking "Enable" in the navigation bar helps.
So, I locate raspbian Jessie lite in the web, download, install to microsd. This time, no update/upgrade before installing pihole. pihole installs.
According to pihole web interface it again says both "DNS service not running" and "FTL offline".
sudo apt-get update fails, the OS can't resolve any hostname whatsoever.
I just don't recall that the installation of my original install of pihole as having any kind of problem whatsoever, IIRC it was soo easy. I just can't seem to find whatever I am missing to get this working. Pi is a Model 3 B, micro sd is 16GB.
I ran the pihole -d of the latest install attempt described above; jessie lite, no apt-get upgrade before pihole install, but it seems it can't upload as the pi can no longer resolve hostnames. So I'll paste below.
pi@raspberrypi:~ $ pihole -d
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations.  This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected.  Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2018-03-25:22:59:02 debug log has been initialized.
[i] Core: v3.3 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v3.3-0-g1e87850
[i] Web: v3.3 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v3.3-0-ge48aa29
[✓] FTL: v3.0 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
*** [ DIAGNOSING ]: dnsmasq version
[i] 2.72
[i] 1.4.35
[i] 5.6.33
[✓] Raspbian GNU/Linux 8 (jessie)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
/opt/pihole/piholeDebug.sh: line 474: $'[\E[32m✓\E[0m] \E[32marmv7l\E[0m': command not found
   192.168.1.5/24 matches the IP found in /etc/pihole/setupVars.conf
   fe80::c14f:3ea1:8d07:d413 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 192.168.1.2
   * Pinging 192.168.1.2...
[✓] Gateway responded.
[22] is in use by sshd
[80] is in use by lighttpd
shuf: /etc/pihole/gravity.list: No such file or directory
dig: '' is not a legal name (unexpected end of input)
[✗] Failed to resolve  via localhost (127.0.0.1)
[✗] Failed to resolve  via Pi-hole (192.168.1.5)
[✓] doubleclick.com is 172.217.4.46 via a remote, public DNS server (8.8.8.8)
[✗] dnsmasq daemon is failed
[✓] lighttpd daemon is active
[✗] pihole-FTL daemon is unknown
    PIHOLE_INTERFACE=eth0
    IPV4_ADDRESS=192.168.1.5/24
    IPV6_ADDRESS=
    PIHOLE_DNS_1=208.67.222.222
    PIHOLE_DNS_2=208.67.220.220
    QUERY_LOGGING=true
    INSTALL_WEB=true
    LIGHTTPD_ENABLED=1
[✗] X-Header does not match or could not be retrieved.
HTTP/1.1 200 OK
Date: Sun, 25 Mar 2018 22:59:06 GMT
Server: lighttpd/1.4.35
[✓] X-Pi-hole: The Pi-hole Web interface is working!
ls: cannot access /etc/pihole/gravity.list: No such file or directory
head: cannot open ‘/etc/pihole/gravity.list’ for reading: No such file or directory
tail: cannot open ‘/etc/pihole/gravity.list’ for reading: No such file or directory
-rw-r--r-- 1 root root 234 Mar 25 22:28 /etc/pihole/logrotate
   /var/log/pihole.log {
        su root root
        daily
        copytruncate
        rotate 5
        compress
        delaycompress
        notifempty
        nomail
   /var/log/pihole-FTL.log {
        su root root
        weekly
        copytruncate
        rotate 3
        compress
        delaycompress
        notifempty
        nomail
-rw-r--r-- 1 root root 1522 Mar 25 22:34 /etc/dnsmasq.d/01-pihole.conf
   localise-queries
   no-resolv
   cache-size=10000
   log-queries=extra
   local-ttl=2
   log-async
   server=208.67.222.222
   server=208.67.220.220
   interface=eth0
-rw-r--r-- 1 root root 3027 Mar 25 22:28 /etc/lighttpd/lighttpd.conf
   server.modules = (
        "mod_access",
        "mod_accesslog",
        "mod_auth",
        "mod_expire",
        "mod_compress",
        "mod_redirect",
        "mod_setenv",
        "mod_rewrite"
   server.error-handler-404    = "pihole/index.php"
   server.pid-file             = "/var/run/lighttpd.pid"
   accesslog.filename          = "/var/log/lighttpd/access.log"
   accesslog.format            = "%{%s}t|%V|%r|%s|%b"
   compress.cache-dir          = "/var/cache/lighttpd/compress/"
   compress.filetype           = ( "application/javascript", "text/css", "text/html", "text/plain" )
   include_shell "/usr/share/lighttpd/create-mime.assign.pl"
' 2>/dev/null"
   $HTTP["url"] =~ "^/admin/" {
           "X-Frame-Options" => "DENY"
       $HTTP["url"] =~ ".ttf$" {
        url.access-deny = ("")
-rw-r--r-- 1 root root 1496 Mar 25 22:28 /etc/cron.d/pihole
   34 4   * * 7   root    PATH="$PATH:/usr/local/bin/" pihole updateGravity
   00 00   * * *   root    PATH="$PATH:/usr/local/bin/" pihole flush once quiet
   */10 *  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker local
   57 13  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
   @reboot root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 516 Mar 25 22:34 /var/log/lighttpd/error.log
   2018-03-25 22:28:35: (log.c.164) server started
   2018-03-25 22:30:33: (server.c.1558) server stopped by UID = 0 PID = 1
   2018-03-25 22:30:40: (log.c.164) server started
   2018-03-25 22:31:56: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning:  unlink(../custom_disable_timer): No such file or directory in /var/www/html/admin/api.php on line 47
   2018-03-25 22:33:59: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning:  unlink(../custom_disable_timer): No such file or directory in /var/www/html/admin/api.php on line 47
-rw-r--r-- 1 dnsmasq root 0 Mar 25 22:28 /var/log/pihole.log
   -----head of pihole.log------
[✓] ** FINISHED DEBUGGING! **
    * For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
    * If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
    * Using openssl for transmission.
[✗]  There was an error uploading your debug log.
   * A local copy of the debug log can be found at: /var/log/pihole_debug-sanitized.log
pi@raspberrypi:~ $
Your version of dnsmasq is too old.
You have two options:
Or: beta-testing FTLDNS :slight_smile:
Thanks. I followed the "How do I revert to a previous version of Pi-hole? FAQs v3-3" and it does now seem to be doing resolution and blocking, it doens't update its stats. No number of domains blocked, no number of queries blocked. No graphs. I've tried different USB power sources, two up to 2.5 amps 5v. One came from osmc and its graphical desktop wasn't alarming about undervoltage before I shut it down to steal its power source for this pi-hole effort.
I've got my teleporter backup, whitelist, blacklist, and dhcp reservations.
At this point, I am losing confidence in it if other things are not working. Even the superficial graphs and counters indicate some malfunction somewhere. This install has been poked and proded, it might be time to call it. If the debug doesn't pin point exactly where it is, you could let me know and I can start all over with a fresh img, but please help me with the right steps to get a 100% working system. Jessie, Jessie lite, or Stretch lite? Do I update/upgrade before installing with the curl script or after?
BTW, earlier yesterday evening, while waiting for your response, I found another microsd and put stretch lite on it, did the update/upgrade, then the curl install. It had the missing graphs and counters too. I'm not sure what I'm missing, I had no issue whatsoever 1-2 years ago when I first setup pi-hole on a pi.
Your debug token is: z9wmhosdt2
OH!, I just noticed a teaser post about the graphs issue affecting someone else. I cleared the cache and all is well with the graphics.
So I'm on;
Pi-hole Version vDev (HEAD, v3.2.1-0-ge602008) Web Interface Version vDev (HEAD, v3.2.1-0-g31dddd8) FTL Version vDev (v2.13.2 , v2.13.2 )
