Frequent DNS Timeout
Multiple times per day i receive a DNS timeout when trying to access the internet. I can see that the DNS has timed out if i try "nslookup www.google.com" on my Windows laptop.
My setup is running Pihole on a Ubuntu VM on HyperV. During the loss of internet connectivity (due to DNS timeout) i can still access the local instance of Pihole which is running on an internal IP (192.xx.xxx.xx) so i dont think its related my network.
The DNS will usually comes back within 5 minutes of hitting the timeout.
Do you have any insights on what the issue could be?
Debug Token: xyqj1e90kr
Thanks
The one thing I note in your debug log is this - the Pi-Hole should be able to resolve a DNS entry using 8.8.8.8.
[✓] 1479646169.xiazaidown.com is 0.0.0.0 via localhost (127.0.0.1)
[✓] 1479646169.xiazaidown.com is 0.0.0.0 via Pi-hole (192.168.86.11)
Run this command from the Pi-Hole host terminal and post the results. This will show if it's repeatable.
dig doubleclick.com @8.8.8.8
Is this problem on any time pattern that you have noticed or is it random?
Did this problem exist before you loaded this block list - https://tspprs.com/dl/cl1 ?
And, what is the output of this command from the Pi-Hole host terminal?
echo ">stats" | nc localhost 4711
Oct, 11: DNS key exchange
https://www.heise.de/newsticker/meldung/DNS-Schuesselwechsel-Wie-man-DNS-Ausfaelle-erkennt-was-dagegen-hilft-4187064.html
Try to disable DNSSEC checkbox in Settings/DNS
I faced the same issues and after unchecking everything went fine. I'm going to re-enable the DNSSEC after a few days.
administrator@pihole:~$ dig doubleclick.com @8.8.8.8
; <<>> DiG 9.11.3-1ubuntu1.2-Ubuntu <<>> doubleclick.com @8.8.8.8
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 4746
;doubleclick.com.               IN      A
doubleclick.com.        299     IN      A       216.58.199.110
;; Query time: 19 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
;; WHEN: Thu Oct 11 13:51:54 UTC 2018
;; MSG SIZE  rcvd: 60
administrator@pihole:~$ echo ">stats" | nc localhost 4711
domains_being_blocked 1146668
dns_queries_today 44840
ads_blocked_today 7977
ads_percentage_today 17.789919
unique_domains 1852
queries_forwarded 19790
queries_cached 17073
clients_ever_seen 4
unique_clients 4
dns_queries_all_types 44857
reply_NODATA 1
reply_NXDOMAIN 9
reply_CNAME 50
reply_IP 73
status enabled
---EOM---
The problem is totally random and with no obvious patterns observed. I should add that i'm using OpenDNS as the upstream DNS if that helps.
Besides let me try disabling this block list and let you know how it goes: https://tspprs.com/dl/cl1
I cant remember what the default selection was but not sure if this has any impact on my issue?
Cheers!
This setting is not enabled on my installation so i'm afraid it's not related to DNSSEC in my case.
