I was to the point when I was installing Pi-hole and install failed. I have not been able to get back into my Debian Install? It keeps asking for password? Is there anyway to start over? I do not think so if I cannot get into system ? Any help would be appreciated.
If you can mount the root partition "/" contained on the disk on another similar Linux system, you can use below to set a new password:
$ man passwd
-R, --root CHROOT_DIR
Apply changes in the CHROOT_DIR directory and use the
configuration files from the CHROOT_DIR directory. Only
absolute paths are supported.
Eg if the root disk partition were mounted on /mnt (check with lsblk) and you want to set password for the root user:
sudo passwd -R /mnt root
This is not possible if the filesystem is encrypted!
