Fix the Stream Deck plugin
After updating my pihole to the latest build (6.0.4), my Stream Deck plugin which was very handy to quickly toggle pihole blocking to ON/OFF stopped working as it relied on the older version of the API token.
How can I obtain the API token to re-enable this plugin?
Regards,
Tareq
Instead of /admin go to /api and it should be there IIRC ?!
Pi-hole API was completely redesigned.
The plugin will need to be updated to support Pi-hole v6. Please contact the app developers.
Huh! there is a stream deck plugin? Do you know who makes it?
I think OP is referring to this one
Oooh, OK.
Looking at the github repo the author has not been active for a while - it may be abandoned.
Might be worth looking at BarRaider's API ninja and rolling your own. If I get super bored when I'm at home I might even look at that myself.
Pi-hole API docs:
Worth a shot... @jholbrook , are you still with us?
Hi folks, thanks for the interest in the plugin.
I definitely want to update the plugin to support the new API but it'll be a while before I get a chance to start on that. In the meantime I'm happy to accept contributions on GitHub. See this issue for more info.
