Fix for CERT vulnerability VU#598349 disappeared
Version 4.2 contains a fix for CERT vulnerability VU#598349.
The file /etc/dnsmasq.d/01-pihole.conf should contain the following lines
# If a DHCP client claims that its name is "wpad", ignore that.
# This fixes a security hole. see CERT Vulnerability VU#598349
dhcp-name-match=set:wpad-ignore,wpad
dhcp-ignore-names=tag:wpad-ignore
I've just noticed in my installed v4.2.1 that the two settings disappeared, only the comment lines exist
Don't know when and why it happend.
Has anyone noticed the same?
Mine still contains it and its on the latest version.
mine contains it, too.
I have those lines intact on three separate installs of V4.2.1
I'll recheck it from time to time, as I definitively know I had them.
Is it by design that disabling DHCP in Pi-hole will change the lines
in 01-pihole.conf to
(Pi-hole Version v4.3, Web Interface Version v4.3, FTL Version v4.3.1)
Thanks for your report. These lines are not needed any longer when disabling DHCP service, however, they could stay there without any harm and should be re-added when enabling the DHCP server. It is unlikely that there are many users lacking this line as it will always be re-added either by repairing (pihole -r) or updating (pihole -up) the Pi-hole. At least the latter is something users will typically be doing.
This bug will be fixed by
https://github.com/pi-hole/pi-hole/pull/2768
Ok, thanks.
In the past weeks the two lines (dhcp-*) disappeared again (2 times) - see my initially reported issue. With enabled DHCP in Pi-hole the lines disappeared after fiddling around with the predefined resolvers and custom ones. I enabled/added some resolvers, disabled some, saved the changes and the lines in 01-pihole.conf have been removed.
