FWIW, this is the output of pihole -up
[i] Checking for updates...
[i] Pi-hole Core: update available
[i] Web Interface: update available
[i] FTL: update available
[i] Pi-hole core files out of date, updating local repo.
[β] Check for existing repository in /etc/.pihole
[i] Update repo in /etc/.pihole...HEAD is now at 19bfa08 Pi-hole core v5.17.3 (#5520)
[β] Update repo in /etc/.pihole
[i] If you had made any changes in '/etc/.pihole/', they have been stashed using 'git stash'
[i] Pi-hole Web Admin files out of date, updating local repo.
[β] Check for existing repository in /var/www/html/admin
[i] Update repo in /var/www/html/admin...HEAD is now at be05b0f v5.21 (#2860)
[β] Update repo in /var/www/html/admin
[i] If you had made any changes in '/var/www/html/admin/', they have been stashed using 'git stash'
[i] FTL out of date, it will be updated by the installer.
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] SELinux not detected
[β] Update local cache of available packages
[i] Existing PHP installation detected : PHP version 7.0.33-0ubuntu0.16.04.16
[β] Checking apt-get for upgraded packages... 6 updates available
[i] It is recommended to update your OS after installing the Pi-hole!
[i] Checking for / installing Required dependencies for OS Check...
[β] Checking for grep
[β] Checking for dnsutils
[β] Unsupported OS detected: Ubuntu 16.04
If you are seeing this message and you do have a supported OS, please contact support.
https://docs.pi-hole.net/main/prerequisites/#supported-operating-systems
If you wish to attempt to continue anyway, you can try one of the following commands to skip this check:
e.g: If you are seeing this message on a fresh install, you can run:
curl -sSL https://install.pi-hole.net | sudo PIHOLE_SKIP_OS_CHECK=true bash
If you are seeing this message after having run pihole -up:
sudo PIHOLE_SKIP_OS_CHECK=true pihole -r
(In this case, your previous run of pihole -up will have already updated the local repository)
It is possible that the installation will still fail at this stage due to an unsupported configuration.
If that is the case, you can feel free to ask the community on Discourse with the Community Help category:
https://discourse.pi-hole.net/c/bugs-problems-issues/community-help/
I ran sudo PIHOLE_SKIP_OS_CHECK=true pihole -r a couple days later, but couldn't capture the output because the console got all messed up. There was a prompt to fix or reset the configuration and I chose fix.
Now lighttpd fails to start.:
Mar 09 23:38:23 server systemd[1]: Starting Lighttpd Daemon...
Mar 09 23:38:24 server lighttpd[10074]: 2024-03-09 23:38:24: (configfile.c.1003) opening configfile /etc/lighttpd/external*.conf failed: No such file or directory
Mar 09 23:38:24 server lighttpd[10074]: 2024-03-09 23:38:24: (configfile.c.957) source: /etc/lighttpd/lighttpd.conf line: 72 pos: 14 parser failed somehow near here: (EOL)
Mar 09 23:38:24 server systemd[1]: lighttpd.service: Control process exited, code=exited status=255
Mar 09 23:38:24 server systemd[1]: Failed to start Lighttpd Daemon.
Mar 09 23:38:24 server systemd[1]: lighttpd.service: Unit entered failed state.
Mar 09 23:38:24 server systemd[1]: lighttpd.service: Failed with result 'exit-code'.
