Hi there,
This is my first Pihole install.
Its a docker on my nomad Laptop, not on a server.
I'd like to acertain I did it well and to understand why unbound doen's want my .conf.
(This is also one of my first containers^^)
I don't shouldn't DHCP as I depend on the various boxes I connect to : my goal is to have Pihole replace the NextDNS I was using in giving me non cheating DNS, ad, trackers, scripts protection.
I'd also like to une DoH, but Unbound doen't want my .conf
Thank ou for your insights !
PC
➜ pihole inxi -z -MSC; free ; swapon -s
System:
Kernel: 6.9.9-1-MANJARO arch: x86_64 bits: 64
Desktop: Xfce v: 4.18.1 Distro: Manjaro Linux
Machine:
Type: Laptop System: HP product: Victus by HP Laptop 16-e0xxx v: N/A
serial: <superuser required>
Mobo: HP model: 8934 v: 80.73 serial: <superuser required> UEFI: AMI
v: F.19 date: 10/17/2023
CPU:
Info: 6-core model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64
type: MT MCP cache: L2: 3 MiB
Speed (MHz): avg: 1403 min/max: 400/4280 cores: 1: 1449 2: 400 3: 400
4: 400 5: 1984 6: 1746 7: 1916 8: 400 9: 2092 10: 2019 11: 1703 12: 2331
total utilisé libre partagé tamp/cache disponible
Mem: 15322 12753 368 658 3187 2569
Échange: 32767 4953 27814
Nom fichier Type Taille Utilisé Priorité
/swapfile file 33554428 5072384 -2
➜ pihole
- .env
WEBPASSWORD=super123456
TZ=Europe/Paris
PIHOLE_DNS_=91.239.100.100;89.233.43.71;9.9.9.9 # Uncensored DNS & fallback & Quad9
*docker-compose.yml
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
ports:
- "5354:53/tcp"
- "5354:53/udp"
- "80:80/tcp"
env_file:
- .env
volumes:
- './etc-pihole:/etc/pihole'
cap_add:
- NET_ADMIN
restart: unless-stopped
deploy:
resources:
limits:
cpus: '0.5'
memory: 512M
reservations:
cpus: '0.2'
memory: 256M
networks:
default:
debug token : https://tricorder.pi-hole.net/LbXThv21/
For unbound.conf
➜ ~ cat /etc/unbound/unbound.conf
server:
interface: 127.0.0.1
port: 5335
do-ip4: yes
do-udp: yes
do-tcp: yes
auto-trust-anchor-file: "/var/lib/unbound/root.key"
msg-cache-size: 128m
rrset-cache-size: 256m
edns-buffer-size: 1472
prefetch: yes
prefetch-key: yes
qname-minimisation: yes
statistics-interval: 0
extended-statistics: yes
hide-identity: yes
hide-version: yes
forward-zone:
forward-tls-upstream: yes
# UncensoredDNS
forward-addr: 89.233.43.71@853#unicast.censurfridns.dk
forward-addr: 91.239.100.100@853#anycast.censurfridns.dk
forward-addr: 2a01:3a0:53:53::@853#unicast.censurfridns.dk
# Quad9
forward-addr: 9.9.9.9@853#dns.quad9.net
forward-addr: 2620:fe::fe@853#dns.quad9.net
➜ ~ sudo unbound-checkconf
[sudo] Mot de passe de sum :
/etc/unbound/var/lib/unbound/root.key: No such file or directory
[1721635472] unbound-checkconf[83349:0] fatal error: auto-trust-anchor-file: "/var/lib/unbound/root.key" does not exist in chrootdir /etc/unbound
