Nothing unusual from my point of view.
This OS had no installed the "iptables" but I installed it manually, No differences, I guess if Firewall had been blocking it, i cannot did the telnet connection.
root@localhost:/home/android# sudo iptables -nL
Chain INPUT (policy ACCEPT)
target prot opt source destination
bw_INPUT all -- 0.0.0.0/0 0.0.0.0/0
fw_INPUT all -- 0.0.0.0/0 0.0.0.0/0
Chain FORWARD (policy ACCEPT)
oem_fwd all -- 0.0.0.0/0 0.0.0.0/0
fw_FORWARD all -- 0.0.0.0/0 0.0.0.0/0
bw_FORWARD all -- 0.0.0.0/0 0.0.0.0/0
natctrl_FORWARD all -- 0.0.0.0/0 0.0.0.0/0
Chain OUTPUT (policy ACCEPT)
wmsctrl_OUTPUT tcp -- 0.0.0.0/0 0.0.0.0/0
DROP udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:1900 /* Drop SSDP on WWAN */
oem_out all -- 0.0.0.0/0 0.0.0.0/0
fw_OUTPUT all -- 0.0.0.0/0 0.0.0.0/0
bw_OUTPUT all -- 0.0.0.0/0 0.0.0.0/0
Chain bw_FORWARD (1 references)
Chain bw_INPUT (1 references)
all -- 0.0.0.0/0 0.0.0.0/0 UNKNOWN match `quota2'
all -- 0.0.0.0/0 0.0.0.0/0 owner socket exists
Chain bw_OUTPUT (1 references)
Chain bw_costly_shared (0 references)
bw_penalty_box all -- 0.0.0.0/0 0.0.0.0/0
Chain bw_happy_box (0 references)
Chain bw_penalty_box (1 references)
Chain fw_FORWARD (1 references)
Chain fw_INPUT (1 references)
Chain fw_OUTPUT (1 references)
Chain natctrl_FORWARD (1 references)
DROP all -- 0.0.0.0/0 0.0.0.0/0
Chain natctrl_tether_counters (0 references)
Chain oem_fwd (1 references)
Chain oem_out (1 references)
Chain wmsctrl_OUTPUT (1 references)
NFQUEUE tcp -- 0.0.0.0/0 127.0.0.1 tcp dpt:40176 STRING match "GET" ALGO name bm FROM 40 TO 200 NFQUEUE num 20 bypass
I'm pretty sure the problem is with the "fsockopen" command, something is going wrong with it or the PHP because no tries to connect anywhere.
Thanks for your effort
