Failing trying to block the roblox site
Pi Hole blocks the Roblox Site
Pi Hole doesn't block Roblox
https://tricorder.pi-hole.net/4bEw6Yvb
Hello Pi Hole Community,
I "successfully" installed Pi Hole a few days ago, it also kinda works now but it doesn't block the Roblox site.
I blocked both roblox.com and rbxcdn.com with both wildcards in it.
I also noticed that the output of nslookup's server is speedport.ip but it should be pi.hole
Server:  speedport.ip
Address:  fe80::1
Nicht autorisierende Antwort:
Address:  128.116.123.3
Thanks if you people can help me!
Did you run the nslookup command from the Pi or from a client from which you can still load Roblox?
I ran the command on my Windows Computer
This computer is not using Pi-hole for DNS.
