Failing to resolve IP of service (container) running alongside pihole
My PiHole is running as a docker container along side my other service nginx on my local raspberry pi. The rpi address is 192.168.1.13.
I am using pihole as a DNS I am want all devices on my network to resolve nginx.home to 192.168.1.13.
I have created a DNS record for nginx.home -> 192.168.1.13
The router is using pihole as a DNS and all ads are getting blocked.
Pihole is acting as my DHCP server.
When I query nginx.home from a device on my network I get
➜  ~ dig nginx.home
; <<>> DiG 9.10.6 <<>> nginx.home
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 6880
;nginx.home.			IN	A
;; Query time: 52 msec
;; SERVER: 192.168.1.1#53(192.168.1.1)
;; WHEN: Wed Apr 24 15:52:34 BST 2024
;; MSG SIZE  rcvd: 38
No answer.
I then created another DNS entry hello.home -> 1.2.3.4
Which gave me;
➜  ~ dig hello.home
; <<>> DiG 9.10.6 <<>> hello.home
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 31357
;hello.home.			IN	A
hello.home.		0	IN	A	1.2.3.5
;; Query time: 88 msec
;; WHEN: Wed Apr 24 15:53:59 BST 2024
;; MSG SIZE  rcvd: 55
This returned the "correct" answer.
From this I take that pihole does not like resolving IP addresses to the machine that itself is running on.
Has anybody else had this problem?
My entry in docker-compose looks like;
  pihole:
    container_name: pihole
    depends_on:
      - traefik
    image: pihole/pihole:2024.03.2
    ports:
      - "53:53/tcp"
      - "53:53/udp"
      - "67:67/udp" # Only required if you are using Pi-hole as your DHCP server
      - "8082:80/tcp"
    environment:
      TZ: 'America/Chicago'
      # WEBPASSWORD: 'set a secure password here or it will be random'
    volumes:
      - ../services/pihole/pihole:/etc/pihole
      - ../services/pihole/etc-dnsmasq.d:/etc/dnsmasq.d
    #   https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
    cap_add:
      - NET_ADMIN
    restart: always
Any help is greatly appreciated!
Tools > Generate Debug Log
Good Morning. The debug token url is https://tricorder.pi-hole.net/QQRNDyVq/
What is the output of: dig nginx.home @192.168.1.13 ?
Above result suggests you have ommitted a space between home and @.
Please run the command exactly as provided by rdwebdesign.
Apologies.
; <<>> DiG 9.10.6 <<>> nginx.home @192.168.1.13
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 55313
;nginx.home.			IN	A
nginx.home.		0	IN	A	192.168.1.13
;; Query time: 54 msec
;; SERVER: 192.168.1.13#53(192.168.1.13)
;; WHEN: Thu Apr 25 21:44:59 BST 2024
;; MSG SIZE  rcvd: 54
That look better. Althought curl gives me
curl -v https://nginx.home
* Could not resolve host: nginx.home
* Closing connection 0
curl: (6) Could not resolve host: nginx.home
