(If you paste links to other forum posts here directly, Discourse automatically takes care to present them in a friendly way - no need to redirect through bit.ly.
Also, you can paste images directly into a post.)
I am not familiar with Synology installations, but calling the installer via the following command should provide some details as to why it stops for you:
Hi Bucking,
Thanks so much for the comments, in the meantime I have purchased a new synology and i am trying to install the pihole on it through docker. You can lock the post.
Thanks coro,
This is what I am currently trying to do through a new synology I have purchased, as I have not been able to install a docker before. In the new one I was able to install the pihole but it does not block ads. I will open another post on occasion, only after I realize I have tried all the guides.
