Failed to create listening socket for port 53: Address already in use
I am trying to setup pihole but my FTL service stays offline I have tried uninstalling dnsmasq and setting up cloudflare still same issue.
I have also tried repair.
failed to create listening socket for port 53: Address already in use
FAILED to start up
https://tricorder.pi-hole.net/15mmywzh63
netstat -nltup | grep 'Proto\|:53 \|:67 \|:80 \|:471 \|:5053'
(Not all processes could be identified, non-owned process info
 will not be shown, you would have to be root to see it all.)
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      -
tcp        0      0 192.168.1.149:53        0.0.0.0:*               LISTEN      -
tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      -
tcp        0      0 127.0.0.1:5053          0.0.0.0:*               LISTEN      -
tcp6       0      0 :::80                   :::*                    LISTEN      -
tcp6       0      0 ::1:53                  :::*                    LISTEN      -
udp        0      0 192.168.1.149:53        0.0.0.0:*                           -
udp        0      0 127.0.0.1:53            0.0.0.0:*                           -
udp        0      0 127.0.0.1:5053          0.0.0.0:*                           -
udp6       0      0 ::1:53                  :::*                                -
[53] is in use by named (https://docs.pi-hole.net/main/prerequisites/#ports)
