Setup new Pi 3 B+ with fresh install of raspbian stretch lite to configure as my Pi-hole. Connected to my router (edgerouter x) directly via ethernet cable. Using SSH I ran the installation script and everything seemed to be working correctly. Reserved a static ip within my router settings for the pi.
However, I was not able to access the web admin page for Pi-hole. Then I noticed that it seems like the installation may have failed because I was not able to use debug command either. I then tried to restart the installation of Pi-hole again and I only get this message now: "Could not resolve host: install.pi-hole.net".. I tried to ping a few sites like CNN.com and got the same message, however I can ping these sites using the IP address and not domain names.
Where do I go from here? Thank you!
Copied SSH text from installation:
root@raspberrypi:/home/pi# curl -sSL https://install.pi-hole.net | bash
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[✓] Disk space check
[✓] Checking apt-get for upgraded packages... 17 updates available
[i] It is recommended to update your OS after installing the Pi-hole!
[✓] Checking for apt-utils
[i] Checking for dialog (will be installed)
[✓] Checking for debconf
[✓] Checking for dhcpcd5
[i] Checking for git (will be installed)
[✓] Checking for iproute2
[✓] Checking for whiptail
[✓] Stopping dnsmasq service...
[✓] Stopping lighttpd service...
[i] Using interface: eth0
[i] Using Google DNS servers
[✓] Set IP address to 192.168.1.175
You may need to restart after the install is complete
[i] Unable to find IPv6 ULA/GUA address, IPv6 adblocking will not be enabled
[i] IPv4 address: 192.168.1.175/24
[i] IPv6 address:
[i] Web Interface On
[i] Logging On.
[✗] Check for existing repository in /etc/.pihole
[✓] Clone https://github.com/pi-hole/pi-hole.git into /etc/.pihole
[✗] Check for existing repository in /var/www/html/admin
[✓] Clone https://github.com/pi-hole/AdminLTE.git into /var/www/html/admin
[i] Main Dependency checks...
[i] Checking for bc (will be installed)
[✓] Checking for cron
[✓] Checking for curl
[i] Checking for dnsmasq (will be installed)
[i] Checking for dnsutils (will be installed)
[✓] Checking for iputils-ping
[i] Checking for lsof (will be installed)
[i] Checking for netcat (will be installed)
[✓] Checking for sudo
[✓] Checking for unzip
[✓] Checking for wget
[i] Checking for idn2 (will be installed)
[i] Checking for sqlite3 (will be installed)
[i] Checking for lighttpd (will be installed)
[i] Checking for php-common (will be installed)
[i] Checking for php-cgi (will be installed)
[i] Checking for php-sqlite3 (will be installed)
root@raspberrypi:/home/pi# reboot
