Facebook, WhatsApp Web, Messenger Kids not working with unbound recursive resolver
After following the instructions for setting up unbound in the Pi-hole as All-Around DNS Solution guide Facebook, WhatsApp Web, Messenger Kids, and Hulu don't resolve reliably: requests for those domains resolve on some devices but not others.
Consistently resolve facebook.com, web.whatsapp.com, Messenger kids, Hulu domains through unbound for all devices connected to the local network. (Local network is set to use Pi-hole as DNS. Pi-hole is set to use unbound as a recursive resolver.)
Most domains resolve fine, but not Hulu, Facebook, and those used by Messenger Kids, WhatsApp Web, and WhatsApp Desktop.
When those domains fail to resolve, folks on the network see "Can't connect to this site" errors in web browsers and "Not connected to the Internet" errors in mobile and desktop apps requesting to unresolved domains.
Per guidance in other threads, I've run dig from the Pi-hole to gather further information on how requests are resolving from the Pi-hole upstream.
"Vanilla" dig
> $ dig web.whatsapp.com
> ; <<>> DiG 9.11.5-P4-5.1-Raspbian <<>> web.whatsapp.com
> ;; global options: +cmd
> ;; Got answer:
> ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 61257
> ;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
> ;; OPT PSEUDOSECTION:
> ; EDNS: version: 0, flags:; udp: 4096
> ;; QUESTION SECTION:
> ;web.whatsapp.com.		IN	A
> ;; ANSWER SECTION:
> web.whatsapp.com.	3390	IN	CNAME	mmx-ds.cdn.whatsapp.net.
> mmx-ds.cdn.whatsapp.net. 60	IN	A	31.13.71.49
> ;; Query time: 12 msec
> ;; SERVER: 127.0.0.1#53(127.0.0.1)
> ;; WHEN: Tue Oct 08 23:51:01 EDT 2019
> ;; MSG SIZE  rcvd: 98
dig via port 5353
> $ dig web.whatsapp.com -p5353
> ;; Warning: Message parser reports malformed message packet.
> ; <<>> DiG 9.11.5-P4-5.1-Raspbian <<>> web.whatsapp.com -p5353
> ;; Got answer:
> ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 21112
> ; EDNS: version: 0, flags:; udp: 1472
> ;; ANSWER SECTION:
> web.whatsapp.com.	53	IN	CNAME	mmx-ds.cdn.whatsapp.net.
> mmx-ds.cdn.whatsapp.net. 28731	RESERVED0 A	\# 4 1F0D4731
> ;; Query time: 2 msec
> ;; SERVER: 127.0.0.1#5353(127.0.0.1)
> ;; WHEN: Tue Oct 08 23:51:08 EDT 2019
dig to @1.1.1.1
> $ dig web.whatsapp.com @1.1.1.1
> ; <<>> DiG 9.11.5-P4-5.1-Raspbian <<>> web.whatsapp.com @1.1.1.1
> ;; Got answer:
> ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 49098
> ;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 0
> ;; ANSWER SECTION:
> web.whatsapp.com.	49	IN	CNAME	mmx-ds.cdn.whatsapp.net.
> mmx-ds.cdn.whatsapp.net. 49	IN	A	31.13.71.49
> ;; Query time: 1 msec
> ;; SERVER: 1.1.1.1#53(1.1.1.1)
> ;; WHEN: Tue Oct 08 23:51:12 EDT 2019
> ;; MSG SIZE  rcvd: 87
Current workaround (doesn't solve WhatsApp problems)
Activating the two OpenDNS IPv4 servers in the settings appears to address the issues accessing Facebook, Messenger Kids, and Hulu. (I'm continuing to watch results for those sites to verify the fix sticks.) Issues accessing WhatsApp Web and WhatsApp Desktop persist.
I chose to add the OpenDNS servers because OpenDNS is marked as supporting ECS, though I assume that this setup doesn't run the ECS requests through unbound, based on this reference to unbound & ECS on Reddit. While that's how I'd prefer to set things up, I don't understand the information on configuring ECS in the unbound man pages well enough to try that approach.
https://tricorder.pi-hole.net/8a3hdqtyl2
Can you provide a copy of the configuration you are using for unbound?
From the unbound configuration manual, this may not be the best option.
edns-buffer-size: <number>
              Number of bytes size to advertise as the EDNS reassembly  buffer
              size.   This  is  the  value put into datagrams over UDP towards
              peers.  The actual buffer size is determined by  msg-buffer-size
              (both  for  TCP  and  UDP).   Do not set higher than that value.
              Default is 4096 which is RFC recommended.  If you have  fragmen-
              tation  reassembly  problems,  usually  seen as timeouts, then a
              value of 1472 can fix it.  Setting to 512 bypasses even the most
              stringent  path  MTU problems, but is seen as extreme, since the
              amount of TCP fallback generated is excessive (probably also for
              this resolver, consider tuning the outgoing tcp number).
For comparison purposes, I ran the same command using Buster and unbound and did not have the same result. Ignore the TTL difference - I have a minimum TTL configured on this install of unbound.
; <<>> DiG 9.10.3-P4-Raspbian <<>> web.whatsapp.com -p5353
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 52360
web.whatsapp.com. 3600 IN CNAME mmx-ds.cdn.whatsapp.net.
mmx-ds.cdn.whatsapp.net. 3600 IN A 157.240.19.53
;; Query time: 288 msec
;; WHEN: Wed Oct 09 10:37:39 CDT 2019
The difference is in this line from your dig result:
As noted by @DanSchaper, we need to look at your unbound configuration. A quick way to see what's in the configuration directories is with this command:
sudo grep -v '#\|^$' -R /etc/unbound/unbound.conf.d
@DanSchaper, thanks for such a quick reply. Here's the unbound config file.
server:
    # logfile: "/var/log/unbound/unbound.log"
    verbosity: 0
    # log-queries: yes
    port: 5353
    do-ip4: yes
    do-udp: yes
    do-tcp: yes
    do-ip6: no
    root-hints: "/var/lib/unbound/root.hints"
    # Trust glue only if it is within the servers authority
    harden-glue: yes
    harden-dnssec-stripped: yes
    use-caps-for-id: no
    # Suggested by the unbound man page to reduce fragmentation reassembly problems
    edns-buffer-size: 1472
    prefetch: yes
    # One thread should be sufficient, can be increased on beefy machines. In reality for most users running on small networks or on a single machine it should be unnecessary to seek performance enhancement by increasing num-threads above 1.
    num-threads: 1
    so-rcvbuf: 1m
    private-address: 10.0.0.0/8
    private-address: fd00::/8
    private-address: fe80::/10
@anon55913113 and @jfb, thanks for the discussion on buffer size. Also, thanks @anon55913113 for the example forward-zone and forward-addr directives and @jfb for the comparison dig.
Here's the current edns-buffer-size:
It appears that timezones are forcing some space into our conversation. Thanks very much to all of you for your patience with that.
Please let me know if there's something in the config file that points to a solution to getting the domains to resolve through unbound without forwarding to another domain server. What I understand from the thread so far, reducing edns-buffer-size may help but generates more TCP fallback than is recommended (excessive per unbound's man page).
I'd love to hear further if there's a way I can better tune my unbound (or perhaps other pi-hole) settings so that all DNS requests run through unbound resolve properly.
Updated workaround
I've updated my workaround based on @anon55913113's forward-zone recommendation, adding forwards to the zones for Facebook, WhatsApp, Hulu and their CDNs. Based on a couple days' testing, this addresses the end-user issue of "why can't I get to Facebook, WhatsApp, etc.?"
# Forward facebook, whatsapp, hulu domains
forward-zone: name: "facebook.com" forward-addr: 1.1.1.1
forward-zone: name: "facebook.net" forward-addr: 1.1.1.1
forward-zone: name: "fbcdn.net" forward-addr: 1.1.1.1
forward-zone: name: "akamaihd.net" forward-addr: 1.1.1.1
forward-zone: name: "whatsapp.com" forward-addr: 1.1.1.1
forward-zone: name: "whatsapp.net" forward-addr: 1.1.1.1
forward-zone: name: "hulu.com" forward-addr: 1.1.1.1
forward-zone: name: "hulustream.com" forward-addr: 1.1.1.1
Privacy cost to workaround?
If I understand this approach properly, it comes at a privacy cost. While Cloudflare promises not to track or sell information on requests to 1.1.1.1, I assume that forwards from unbound to an upstream DNS server are sent in the clear like "normal" DNS requests.
Have I understood that properly?
Thanks for the update on encrypting traffic when forwarding.
I haven't executed it successfully yet because I'm not sure what .pem file to reference. The cert bundles on my machine don't match the example in https://dnsprivacy.org/wiki/m/mobile.action#page/1278020. Searching for info on what .pem to use for a secure connection with cloudflare-dns.com I've come up empty. Where would you recommend I look for additional information on what .pem to use?
Thanks very much for all your help. As your previous response on forwarding requests addressed the original problem I raised, I've marked that response as the solution.
This approach did the trick. It's now tested successfully for over a week. Thanks very much for the follow up help.
