instead of lighttpd
Without any changes from my end, PI-Hole started to not resolve or resolve very slowly all DNS lookups. I tried turning off and on DNSsec validation to see if it helped. I made sure I updated the rasp pi and the pi.hole to the latest versions also. Seems not to have done anything. Can you check log output for anything interesting or wrong? I rebooted the rasp pi a few times. I powered it off, pulling power out also just to be sure, no help.
DNS Resolution has not been an issue. When devices are configured with same Quad9 ip's for direct lookup, it works fine.
