This was my post, and what I marked as my own solution does not work anymore. I had to start from scratch with my setup and I'm encountering the same issue. I can't unmark the previous solution, but it definitely doesn't work as I said it did.
Continuing the discussion from External Custom Domain inside LAN:
instead of lighttpd
[Replace this text with what you think should be happening. Please include as much detail as possible including, but not limited to:
-operating system
-hardware]
[Replace this text with the debug token provided from running pihole -d
(or running the debug script through the web interface]
