Expose DNS Rate-Limit settings in the Web UI
Feature Request: Expose DNS Rate-Limit settings in the Web UI
Problem
Currently, DNS rate-limiting settings (dns.rateLimit.count and dns.rateLimit.interval) are hidden from the Web UI. For advanced users, adjusting these values often requires direct configuration file editing (pihole.toml). In Pi-hole v6, manual edits to these files are sometimes reverted by the FTL engine upon service restart, forcing users to resort to filesystem-level workarounds (e.g., chattr +i) to maintain their desired configuration.
Use Case
I am a power user running a home lab environment with high-frequency local networking tools (e.g., Input Leap / Barrier). These tools occasionally generate a burst of DNS requests during reloads, which triggers a "false positive" rate-limit flag in FTL.
Because the default rate-limit is too aggressive for this specific local traffic, I had to manually increase the limits to prevent my legitimate local traffic from being "Refused" (Error 5).
Proposed Solution
Expose a section in Settings > DNS (or an "Advanced" tab) that allows authorized users to:
  1. View current rate-limit settings.
  2. Toggle or modify the count and interval values.
This would prevent the need for users to manually edit the .toml file and subsequently lock it via chattr, which is a fragile solution for an otherwise standard networking configuration.
This is already available via Settings | All settings » DNS server:
All settings is available in Expert mode only.
They are not hidden.
These options are already on the Settings > DNS page:
  1. Click on the "Basic" switch to change it to "Expert":
  2. Scroll down and find the Rate-limiting options:
    The first box is dns.rateLimit.count. The second one is dns.rateLimit.interval.
AFAIK changes to the pihole.toml file should have the same effect as changing things via the webGUI and never revert to old values or some sort of backup version of the file ?!?! :face_with_raised_eyebrow:
Yes.
thanks didnt know that pihole would hase a basic version as i dont think the avarage user would need one
