Export an adlist
Is there a way to export an adlist list? The source (url/webpage) of one of my adlists has gone "404: Not Found" so I can't just click the link to get it online. I've also done some searches for it with no luck. So I'd like to get a copy of it from my (rPi) Pi-Hole, if that's possible. Thanks.
There should be a local copy in /etc/pihole/
Ah, found it.
"/etc/pihole/list.#.githubusercontent.com.domains" with # being the number of the list.
Thanks. I was afraid I'd have to figure out the sql database stuff.
I wrote the the name out incase anyone else comes searching for the info.
The number # will vary for each user, depending on how many adlists they are using.
