I just wanted to ask, if there is anybody out there who has some experience with Pihole on Ubuntu and have also installed Webmin.
Currently I have installed Pihole on Ubuntu 20.04.3 LTS and I'm planning to install Webmin.
But I do not have much experience here and do not want to destroy the current environement.
I found some helpful manuals out there, where I could install webmin already very easy on a virtual machine. But this one was without a pihole installation.
So I wanted to ask you here, if maybe anybody else has some expierience with it and can share some best practices.
long time since i used webmin but it doesn't run on lighttpd which pi-hole does by default.
webmin also uses a different default port (10000 if i remember correctly) and pi-hole uses port 80 so i don't see why they can't happily run on the same system.
I have both pihole and webmin running (baremetal, no docker container) on a Raspberry Pi 3B. It works fine. You access pihole interface via port 80 and webmin interface via port 10000; therefore no conflicts.
