Existing DNSMASQ + Pi-Hole
Use existing installed DNSMASQ together with pi-hole FTL without interuptions
DNS service is not started during installation
Debug Token: ersoo8bxnd
Hi, I'm using my PI as DNS and DHCP server with DNSMASQ, I tried to install pi-hole but it could not start dns service.
Then I learned that it's using own FTL dns. Is there any way to install pi-hole without interupting existing dns / dhcp?
Pi-Hole will perform both of these functions. Your existing dnsmasq configuration files can still be used.
You will need to stop dnsmasq so pihole-FTL can listen on port 53. Then Pi-Hole will work properly. From your debug log, dnsmasq is on port 53.
*:5900 vncserver- (IPv6)
*:5900 vncserver- (IPv4)
*:22 sshd (IPv4)
*:22 sshd (IPv6)
*:80 lighttpd (IPv4)
*:80 lighttpd (IPv6)
*:53 dnsmasq (IPv4)
*:53 dnsmasq (IPv6)
[✓] dnsmasq daemon is active
[✓] lighttpd daemon is active
[✗] pihole-FTL daemon is inactive
@jfb Thanks for the tip, could please tell me at which point I need to stop dnsmasq?
Because I get no DNS if I disable it before installation and installation needs dns.
And it during the installation it says:
Stopping DNS service
Starting DNS service -> but this finishes with timeout and DNS service is never started (when I ran install script as user)
Then I ran installation as root, it went through but FTL does not work correctly and when I enter web admin page all graphs are just loading but does not show anything.
here is the log
Oct 09 06:24:07 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Oct 09 06:24:07 raspberrypi pihole-FTL[10586]: Not running
Oct 09 06:24:07 raspberrypi pihole-FTL[10586]: chown: cannot access '/etc/pihole/dhcp.leases': No such file or directory
Oct 09 06:24:07 raspberrypi su[10613]: Successful su for pihole by root
Oct 09 06:24:07 raspberrypi su[10613]: + ??? root:pihole
Oct 09 06:24:07 raspberrypi su[10613]: pam_unix(su:session): session opened for user pihole by (uid=0)
Oct 09 06:24:08 raspberrypi pihole-FTL[10586]: dnsmasq: cannot open or create lease file /var/lib/misc/dnsmasq.leases: Permission denied
Oct 09 06:24:08 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
Oct 09 06:27:00 raspberrypi systemd[1]: Stopping LSB: pihole-FTL daemon...
Oct 09 06:27:00 raspberrypi pihole-FTL[10965]: Not running
Oct 09 06:27:00 raspberrypi systemd[1]: Stopped LSB: pihole-FTL daemon.
Oct 09 06:33:49 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Oct 09 06:33:49 raspberrypi pihole-FTL[11876]: Not running
Oct 09 06:33:49 raspberrypi pihole-FTL[11876]: chown: cannot access '/etc/pihole/dhcp.leases': No such file or directory
Oct 09 06:33:49 raspberrypi su[11901]: Successful su for pihole by root
Oct 09 06:33:49 raspberrypi su[11901]: + ??? root:pihole
Oct 09 06:33:49 raspberrypi su[11901]: pam_unix(su:session): session opened for user pihole by (uid=0)
Oct 09 06:33:52 raspberrypi pihole-FTL[11876]: dnsmasq: cannot open or create lease file /var/lib/misc/dnsmasq.leases: Permission denied
Oct 09 06:33:52 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
I tried already but it did not work and I got no DNS resolution, there must be some config file or something missing.
You will likely need root user privileges to stop dnsmasq:
sudo service dnsmasq stop
sudo service dnsmasq disable
sudo service pihole-FTL restart
This command will completely remove dnsmasq from your system (except for the one included in FTL):
sudo apt-get remove dnsmasq
