instead of lighttpd
Expect ads to be blocked
The web dashboard and interface works fine. But hardly any queries get blocked. The dashboard says out of 5842 total queries, 22 are blocked -- that's 0.4% of queries blocked. I'm seeing tons of ads everywhere. I did the standard automatic installation (except that I had to opt out of the version checking) on a Raspberry Pi 4B. Last month, I had the same setup and everything was wonderful, but last week the Pi died. Pi Hole on the new Pi doesn't block at all.
https://tricorder.pi-hole.net/QgWwVWVD/
TIA
