Just wanted to thank you guys for this new AWESOME config file and let you know that it makes me VERY HAPPY
I just edited the following stuff :
- etc_dnsmasq set to TRUE to be able to create /etc/dnsmasq.d/10-MySettings.conf and the Unbound related configuration line in it :
- Changed the Webserver IP address/Ports value to 192.168.1.3:443so instead of the default "All IPv4 and IPv6 Interfaces on Ports 80 and 443" values.
And a quick question :
Will all the settings/options in /etc/pihole/pihole.toml eventually be available via the webGUI in "All Settings" sub-menu ?
They are already there.
See below:
Did you mean etc_dnsmasq_d?
- Settings > All Settings > Webserver and API tab >
webserver.port option:
DL6ER
3
This is already the default value for almost two years:
We should probably remove this recommendation from the unbound guide. And you can remove the extra config file/option.
Thanks!
Must have somehow misunderstood the webGUI part and got excited by the way the pihole.toml is set up with all the nice commenting and everything
Thanks for the link/reference!
