/etc/lighttpd/conf.d does not exist
Hello, i am new to this, have raspberry pi zero 2w and i can not find a solution to the following problem
Pi hole was supposed to be connected to my network and block adds.
I have access to the pi hole interface/ panel from my browser and everything seems ok. But adblock doesn't work at all.
I check my modem and raspberry isn't listed on the connected devices.
The problem i think might be here: /etc/lighttpd/conf.d does not exist.
https://tricorder.pi-hole.net/gEhEbLBc/
Sorry if my post isnt written properly but i am really confused.
Thanks a lot ppl
Your operating system is Debian (Raspberry Pi OS):
[✓] Distro:  Debian
Only Fedora/CentOS family has that directory.
The message you saw is expected in Debian.
The screenshot shows your Pi-hole is blocking ads (869 queries - 10,6%).
The debug log shows your Pi (192.168.1.13) is blocking ads.
During the debug log tests, the domain www.connectiviitebl.online was correctly blocked.
   Mar  2 00:44:21 dnsmasq[3824]: query[A] www.connectiviitebl.online from 192.168.1.13
   Mar  2 00:44:21 dnsmasq[3824]: gravity blocked www.connectiviitebl.online is 0.0.0.0
Apparently everything is working fine, even if your modem/router doesn't show your Raspberr Pi IP 192.168.1.13.
