Errors when updating PiHole
Hi i get this error whenever i try Pihole -up or Pihole -g.
I have over 120g free on the drive and doesn't look like there are any other issues with storage. PIhole works as expected.
any ideas?
https://tricorder.pi-hole.net/VgEODQoK/
[i] Creating new gravity databases...
[✗] Unable to copy data from /etc/pihole/gravity.db to /etc/pihole/gravity.db_temp
Runtime error near line 42: disk I/O error (10)
[i] Attempting to restore previous database from backup no. 1
[✓] Cleaning up stray matter
[✓] FTL is listening on port 53
[✓] UDP (IPv4)
[✓] TCP (IPv4)
[✓] UDP (IPv6)
[✓] TCP (IPv6)
You're getting a disk I/O error—likely due to file corruption or permission issues, not space.
:white_check_mark: Quick Fix:
  1. Stop Pi-hole:
    sudo service pihole-FTL stop
  2. Delete corrupted DB:
    sudo rm /etc/pihole/gravity.db
  3. Rebuild gravity DB:
    sudo pihole -g
    sudo service pihole-FTL start
If issue persists, run sudo fsck on your SD card and check dmesg for hardware errors. Let me know if you're on Docker or Pi.
