ERROR : no address range available for DHCP request via wlan0
Hi, I am running Pi-Hole on a Raspberry Pi 2B. And i have set it up using Portainer and Docker.
I was able to successfully run the Pi-Hole on my network. However, i noticed the only client that is being shown is my routers IP. 198.162.1.1.
Hence, i changed my Pi-Hole from Bridged to Host. And changed it to be the DHCP.
I disabled the DHCP on my router as well.
The DHCP range i provided in Pi-Hole is 172.17.0.3 to 172.17.0.251.
Need to see separate clients in Pi-Hole.
When i set it up as DHCP and in Host more. With no ports defined.
Getting error -
no address range available for DHCP request via veth17e8cd1
DHCP packet received on eth0 which has no address
no address range available for DHCP request via lo
https://tricorder.pi-hole.net/yjrxArPj/
Other info -
When i put the DHCP range as 192.168.1.2 to 254, i got a different error (as was present on my router).
no address range available for DHCP request via eth0.
My router is on 192.168.1.1.
When i do ipcongif on laptop, i get the routers IP.
Pi-hole is on 192.168.1.41. - And has been set as my only DNS on Router.
Edit 1 -
After going through the below article : DHCP not assigning IPs - #4 by Bucking_Horn
I enabled port 67 for Pi-Hole. Though i dont see any errors, i am unable to connect to internet from new devices.
Enabling port 67 seems to have fixed the issue. - DHCP not assigning IPs - #4 by Bucking_Horn
Though, still sometimes, some of the queries are going via the routers IP.
