Good day. I am using Manjaro and since pi-hole doesn't support Manjaro, I am planning to run in via a docker. However, everytime I run docker-compose up --detach
, it gives me this error
[Hori ~]# docker-compose up --detach
Creating network "root_default" with the default driver
Creating pihole ...
Creating pihole ... error
ERROR: for pihole Cannot start service pihole: driver failed programming external connectivity on endpoint pihole (c88d0a30952642ddda57c2da0af6d7ec33491556c21377ef5063296940e5ff1a): Error starting userland proxy: listen tcp4 0.0.0.0:80: bind: address already in use
neofetch
██████████████████ ████████ root@Hori
██████████████████ ████████ OS: Manjaro Linux x86_64
██████████████████ ████████ Host: Aspire A514-53 V1.16
████████ ████████ Kernel: 5.14.7-2-MANJARO
████████ ████████ ████████ Uptime: 4 hours, 33 mins
████████ ████████ ████████ Packages: 1530 (pacman)
████████ ████████ ████████ Shell: bash 5.1.8
████████ ████████ ████████ Resolution: 1366x768
████████ ████████ ████████ DE: KDE5
████████ ████████ ████████ WM: KWin
████████ ████████ ████████ Theme: [KDE5], Breeze [GTK2/3]
████████ ████████ ████████ Icons: [KDE5], breath2 [GTK2/3]
████████ ████████ ████████ Terminal: konsole
CPU: Intel i3-1005G1 (4) @ 3.400GHz
GPU: Intel Iris Plus Graphics G1
Memory: 4143MiB / 7630MiB
inxi -Fazy
System:
Kernel: 5.14.7-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=3e711149-8ebe-45af-8e9a-78a1cdacff3f rw quiet apparmor=1
security=apparmor resume=UUID=d27dc7f4-ce4f-48b8-ba69-9971d9cc4ca0
udev.log_priority=3
Console: tty pts/4 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Machine:
Type: Laptop System: Acer product: Aspire A514-53 v: V1.16 serial: <filter>
Chassis: type: 10 serial: N/A
Mobo: IL model: Sneezy_IL v: V1.16 serial: <filter> UEFI: Insyde v: 1.16
date: 01/18/2021
Battery:
ID-1: BAT0 charge: 32.8 Wh (100.0%) condition: 32.8/53.0 Wh (62.0%)
volts: 16.6 min: 15.4 model: PANASONIC KT004 AP19B5L type: Li-ion
serial: <filter> status: Full cycles: 386
CPU:
Info: Dual Core model: Intel Core i3-1005G1 socket: U3E1 bits: 64
type: MT MCP arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5
microcode: A6 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 9524
Speed: 3236 MHz min/max: 400/3400 MHz base/boost: 3400/8300 volts: 0.9 V
ext-clock: 100 MHz Core speeds (MHz): 1: 3236 2: 3304 3: 3335 4: 3333
Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-6:7
chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
Display: server: X.Org 1.20.13 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 112 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.2.2
direct render: Yes
Audio:
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0401
Device-2: C-Media USB PnP Sound Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:20 chip-ID: 0d8c:013a
class-ID: 0300
Sound Server-1: ALSA v: k5.14.7-2-MANJARO running: yes
Sound Server-2: sndio v: N/A running: no
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.37 running: yes
Network:
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
port: 4000 bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
IF: wlp0s20f3 state: up mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
IF-ID-1: br-51f3ddb93098 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-10:8 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: N/A rfk-block:
hardware: no software: no address: see --recommends
RAID:
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 30 class-ID: 0104
Device-1: md126 maj-min: 9:126 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 2136 chunk-size: N/A
Components: Online: N/A Spare:
0: nvme0n1 maj-min: 259:0 size: 476.94 GiB state: S
Device-2: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 2944 chunk-size: N/A
0: nvme1n1 maj-min: 259:5 size: 27.25 GiB state: S
Drives:
Local Storage: total: 1.4 TiB used: 187.69 GiB (13.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: HBRPEKNX0202A
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: G002 temp: 29.9 C
SMART: yes health: PASSED on: 228d 15h cycles: 1,702
read-units: 12,246,685 [6.27 TB] written-units: 26,834,539 [13.7 TB]
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Intel model: HBRPEKNX0202AO
size: 27.25 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: K5110440 temp: 35.9 C
SMART: yes health: PASSED on: 275d 21h cycles: 1,703
read-units: 39,631,078 [20.2 TB] written-units: 42,577,561 [21.7 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
family: Barracuda 2.5 5400 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: 0001 temp: 38 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 241d 22h cycles: 1677
read: 4.5 TiB written: 3.22 TiB Old-Age: g-sense error rate: 273 Pre-Fail:
attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
Partition:
ID-1: / raw-size: 200 GiB size: 195.86 GiB (97.93%) used: 99.78 GiB (50.9%)
fs: ext4 block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 308 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda4 maj-min: 8:4
Swap:
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
Sensors:
System Temperatures: cpu: 67.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info:
Processes: 214 Uptime: 4h 33m wakeups: 1 Memory: 7.45 GiB
used: 4.39 GiB (59.0%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: apt: 0 pacman: 1530 lib: 424 flatpak: 0
Shell: Bash (sudo) v: 5.1.8 running-in: konsole inxi: 3.3.06
netstat -tulpn | grep LISTEN
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 618/pihole-FTL
tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 595/cupsd
tcp 0 0 127.0.0.1:4711 0.0.0.0:* LISTEN 618/pihole-FTL
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 745/nginx: master p
tcp6 0 0 :::53 :::* LISTEN 618/pihole-FTL
tcp6 0 0 ::1:631 :::* LISTEN 595/cupsd
tcp6 0 0 ::1:4711 :::* LISTEN 618/pihole-FTL
tcp6 0 0 :::80 :::* LISTEN 745/nginx: master p
tcp6 0 0 :::1716 :::* LISTEN 1389/kdeconnectd
nano /etc/resolv.conf
GNU nano 5.8 /etc/resolv.conf
# Generated by NetworkManager
nameserver 1.1.1.1
nameserver 1.0.0.1
nameserver 2606:4700:4700::1111
# NOTE: the libc resolver may not support more than 3 nameservers.
# The nameservers listed below may not be recognized.
nameserver 2606:4700:4700::1001
[ Read 7 lines ]
^G Help ^O Write Out ^W Where Is ^K Cut ^T Execute
^X Exit ^R Read File ^\ Replace ^U Paste ^J Justify
nano /etc/resolvconf.conf
GNU nano 5.8 /etc/resolvconf.conf
# Configuration for resolvconf(8)
# See resolvconf.conf(5) for details
name_servers="::1 127.0.0.1"
resolv_conf_options="trust-ad"
resolv_conf=/etc/resolv.conf
private_interfaces="*"
# Write out unbound configuration file
unbound_conf=/etc/unbound/resolvconf.conf
# If you run a local name server, you should uncomment the below line and
# configure your subscribers configuration files below.
#name_servers=127.0.0.1
[ Read 11 lines ]
