Hi, I'm trying to install pihole on a raspberry pi.
The starting installation comes from an octoprintimage (based on a raspbian buster).
I've already installed pihole on a clean raspbian on a pizero and I didn't faced this problems.
I've created an user in sudoers, and launched:
 curl -sSL https://install.pi-hole.net | sudo bash
But it shows this error:
Error: Could not update local repository. Contact support
I've then tried with -x option:
 curl -sSL https://install.pi-hole.net | sudo bash -x
And the problem seems to be related to cloning the https://github.com/pi-hole/pi-hole.git into /etc/.pihole.
I've then tried running the installer using root user, root check pass obviously, but the problem arises again.
I've then tried cloning manually the repo, it works, but then when trying the installer again, this time it complains about the repo already existing.
Any suggestion?
