instead of lighttpd
Running Pi-Hole on Raspbian and expect to be able to see the dashboard/update lists, etc.
I can't see my ad lists, or any groups or statistics from the web interface. From inspecting with dev tools in Chrome I can see that it's giving me an error that it's unable to open the gravity database.
I do see the gravity.db file, the debug doesn't appear to show anything obviously wrong (IPv6 doesn't work but that's expected as I disabled it on the Pi). (I also ran a repair and that didn't change anything)
