instead of lighttpd
[Replace this text with what you think should be happening. Please include as much detail as possible including, but not limited to:
-operating system
-hardware]
[i get a ERR_CONNECTION_REFUSED from my web browser when trying to log into my admin panel, i cant get it to work]
