Entries in blacklist should be sorted alphabetically in web GUI
Please ensure that you are running the latest version of the beta code.
Run pihole -up to update to the latest, then verify that the problem still exists before reporting it.
Problem with Beta 5.0:
In version 4.x, entries in the blacklist are displayed sorted alphabetically. It makes it easier to look through the list later. In the beta, the list appears to be displayed in the order that entries were added.
I added screenshots just in case it’s not clear.
https://imgur.com/a/GC0w6iB
Sorted alphabetically would be more useful. It’s more of a feature request than a bug report.
You can sort each column. If you select the sort icon next to domain/regex, you will see them in forward or backward alphanumeric order. You can also sort the type at the same time, so the blacklist entries appear at the top in alphabetical order.
