Enabling ShopAtHome
I was wondering if there is a way to enable ShopAtHome.com while still using Pi-Hole; my wife uses it for a lot things. ShopAtHome.com uses many domains to redirect to their site.
I am using multiple adlists but whitelisted shopathome.com and it still won't work.The site loads, but the redirects do not.
These tools can help.
Also, if the website is only being loaded from one computer, you can put that computer on a separate management group and tailor the blocking on that group. This would whitelist domains for that group only, leaving them blocked for other clients.
