Enabling HTTPS for your Pi-hole Web Interface
The block page is the 404 page, so you will only get it when visiting a page which does not exist.
Like many others, I use my own certificate from my own Windows CA....
I tried this but I can only connect to the Pi-Hole thru HTTPS using the IP; I cannot access it using the hostname or the FQDN.
When I try, Chrome gives me:
ERR_SSL_UNRECOGNIZED_NAME_ALERT
The certificate is correct and I am accessing the correct hostname and FQDN
How do I fix this?
The hostname/FQDN needs to be presented in the pem cert as a Subject CN (Common name) or as a SAN (Subject alternative name):
pi@noads:~ $ openssl x509 -in pi.hole.pem -noout -text
        Issuer: C = US, ST = MN, L = Minneapolis, OU = Domain Control Validated, CN = some.cert.signer.ca
        Subject: C = US, ST = MN, L = Minneapolis, OU = Domain Control Validated, CN = noads.dehakkelaar.nl
            X509v3 Subject Alternative Name:
                DNS:pi.hole
C=US ST=WY L=Sheridan
I just blindly entered through those settings using openssl defaults.
They dont matter anyway :wink:
EDIT:
http://apetec.com/support/GenerateSAN-CSR.htm
Been staring at this for bout half an hour trying to find cryptic hidden message :wink:
No offense but this isnt the first or the last certificate Ive made.
I just checked it anyways and it is correct: Its in the CN and the SAN.
Also like I mentioned, If I go to the IP, it works correctly.
And you get the right cert presented ? (substitute <IP_ADDRESS_OR_DOMAIN_HERE>)
echo | openssl s_client -connect <IP_ADDRESS_OR_DOMAIN_HERE>:443 2>/dev/null | openssl x509 -text -noout
If I use = for wildcard, I get thus far:
WhY danSC===er U STLSi
For the CSR. Country is US, State is WY, Locality is Sheridan
Yeah but whats the cryptic part ?
:wink:
I don't understand what you mean?
That makes two :smiley:
I dont understand relevance of below posting:
Thats why I was looking for cryptic hidden message :wink:
@riahc3 , forgot to mention, you could run below one too to see cert details presented like CN & SAN:
curl -Iv https://<DOMAIN>
Sometimes results differ from using openssl when inspecting a socket depending on how the web server is configured.
From the cert:
Yeah that was a cert I created once for testing.
When the questions came about location, I just pressed enter to accept defaults :wink:
Those are defaults? Oh, I thought you were putting in the location of where Pi-hole was first created!
Something must have changed in meantime (updated openssl or something) as I cant reproduce:
pi@noads:~/tmp $ openssl req -new -out pi.hole.csr -key pi.hole.key
You are about to be asked to enter information that will be incorporated
into your certificate request.
What you are about to enter is what is called a Distinguished Name or a DN.
There are quite a few fields but you can leave some blank
For some fields there will be a default value,
If you enter '.', the field will be left blank.
Country Name (2 letter code) [AU]:
State or Province Name (full name) [Some-State]:
Locality Name (eg, city) []:
Organization Name (eg, company) [Internet Widgits Pty Ltd]:
Organizational Unit Name (eg, section) []:
Common Name (e.g. server FQDN or YOUR name) []:pi.hole
Email Address []:
Please enter the following 'extra' attributes
to be sent with your certificate request
A challenge password []:
An optional company name []:
pi@noads:~/tmp $ openssl req -text -noout -in pi.hole.csr
        Subject: C = AU, ST = Some-State, O = Internet Widgits Pty Ltd, CN = pi.hole
Now we know :wink:
