Enabling HTTPS for web interface on Pi hole fails
Hi guys,
I've been following the following article (and few others) to enable HTTPS on Pi-hole (which I've done in the past successfully) but I struggle... Enabling HTTPS for your Pi-hole Web Interface
Could you please give me some hints on this?
Here is my config of the Lighttpd.conf and external.conf files:
lighttpd.conf
# Lighttpd config for Pi-hole
#     FILE AUTOMATICALLY OVERWRITTEN BY PI-HOLE INSTALL/UPDATE PROCEDURE.     #
#              CHANGES SHOULD BE MADE IN A SEPARATE CONFIG FILE:              #
#                         /etc/lighttpd/external.conf                         #
server.modules = (
    "mod_access",
    "mod_accesslog",
    "mod_auth",
    "mod_expire",
    "mod_redirect",
    "mod_setenv",
    "mod_rewrite",
    "mod_openssl"
server.error-handler-404    = "/pihole/index.php"
#server.upload-dirs          = ( "/var/cache/lighttpd/uploads" )
server.pid-file             = "/run/lighttpd.pid"
accesslog.filename          = "/var/log/lighttpd/access.log"
accesslog.format            = "%{%s}t|%V|%r|%s|%b"
mimetype.assign = (
    ".ico"   => "image/x-icon",
    ".jpeg"  => "image/jpeg",
    ".jpg"   => "image/jpeg",
    ".png"   => "image/png",
    ".svg"   => "image/svg+xml",
    ".css"   => "text/css; charset=utf-8",
    ".html"  => "text/html; charset=utf-8",
    ".js"    => "text/javascript; charset=utf-8",
    ".json"  => "application/json; charset=utf-8",
    ".map"   => "application/json; charset=utf-8",
    ".txt"   => "text/plain; charset=utf-8",
    ".eot"   => "application/vnd.ms-fontobject",
    ".otf"   => "font/otf",
    ".ttc"   => "font/collection",
    ".ttf"   => "font/ttf",
    ".woff"  => "font/woff",
    ".woff2" => "font/woff2"
# Add user chosen options held in external file
# This uses include_shell instead of an include wildcard for compatibility
# default listening port for IPv6 falls back to the IPv4 port
# Prevent Lighttpd from enabling Let's Encrypt SSL for every blocked domain
#include_shell "/usr/share/lighttpd/include-conf-enabled.pl"
include_shell "find /etc/lighttpd/conf-enabled -name '*.conf' -a ! -name 'letsencrypt.conf' -printf 'include \"%p\"\n' 2>/dev/null"
# If the URL starts with /admin, it is the Web interface
$HTTP["url"] =~ "^/admin/" {
    # Create a response header for debugging using curl -I
        "X-Frame-Options" => "DENY"
# Block . files from being served, such as .git, .github, .gitignore
    url.access-deny = ("")
# allow teleporter iframe on settings page
$HTTP["url"] =~ "/teleporter\.php$" {
    $HTTP["referer"] =~ "/admin/settings\.php" {
        setenv.add-response-header = ( "X-Frame-Options" => "SAMEORIGIN" )
# Default expire header
expire.url = ( "" => "access plus 0 seconds" )
external.conf
$HTTP["host"] == "pihole.domain.tld" {
  # Ensure the Pi-hole Block Page knows that this is not a blocked domain
  setenv.add-environment = ("fqdn" => "true")
  # Enable the SSL engine with a LE cert, only for this specific host
  $SERVER["socket"] == ":4443" {
    ssl.engine = "enable"
    ssl.pemfile = "/etc/letsencrypt/live/pihole.domain.tld/web.pem"
    ssl.ca-file =  "/etc/letsencrypt/live/pihole.domain.tld/fullchain.pem"
    ssl.honor-cipher-order = "enable"
    ssl.cipher-list = "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH"
    ssl.use-sslv2 = "disable"
    ssl.use-sslv3 = "disable"
  # Redirect HTTP to HTTPS
  $HTTP["scheme"] == "http" {
    $HTTP["host"] =~ ".*" {
      url.redirect = (".*" => "https://%0$0")
When I restart the service I get:
2021-12-15 18:43:05: configfile.c.2274) server.upload-dirs doesn't exist: /var/cache/lighttpd/uploads
2021-12-15 18:43:05: plugin.c.195) dlopen() failed for: /usr/lib/lighttpd/mod_openssl.so /usr/lib/lighttpd/mod_openssl.so: cannot open shared object file: No such file or directory
2021-12-15 18:43:05: server.c.1238) loading plugins finally failed
I'm running Debian 11 on a Raspberry 2B here.
I can generate the debug logs for Pihole if it's useful.
Thanks!
Hey mate, I am wholly incapable of assisting you but the team will probably need your Pihole version at a minimum and/or the debug log if you want them to be able to help you
