thank you very much! The token is: 65f5rmj46c
i think i saw a problem with this: [i] Default IPv4 gateway: 192.168.2.1
I think that is the problem - your defined gateway is on entirely different range.
192.168.178.199/24 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
* Pinging 192.168.2.1...
[✓] www.prjcode.com is 0.0.0.0 via localhost (127.0.0.1)
[✓] www.prjcode.com is 0.0.0.0 via Pi-hole (192.168.178.199)
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.178.199
pihole -r
and select "reconfigure"
@jfb
Thank you, I tried to reconfig it, and changed the wrong IP address to the right one (192.168.178.1) than I restarted the Pi.
I tried to update the lists, but same problem. Generated a new debug log and saw the same Problem:
I dont know why, because i changed it
Edit /etc/dhcpcd.conf
and fix the entry there as required. Then restart the Pi.
@jfb thank you very much, now it works!
Little question, i have 3 similar entrys is this right? The first one was the wrong entry
interface eth0
static ip_address=**192.168.178.199/24**
** static routers=192.168.178.1**
interface eth0
static ip_address=192.168.178.199
interface eth0
static ip_address=192.168.178.199/24
You only need one entry for the interface. Delete two of them and make sure the remaining one is correct. The last one looks correct, with the /24 subnet and the correct router and DNS servers. I would delete the first two.
Ich habe das genau so gemacht, leider bekomme ich die Meldung:
Status: Not found/empty list
List download failed: no cached list available
die File liegt im file://home/pi/blocklist-1
das habe ich genau so im PiHole unter Groupmanagement/Adlist eingetragen
Es gibt einen kleinen Unterschied: es müssen 3x /
sein
file:///home/pi/blocklist-1
Ich Schaf. Danke dir
Hi habe wie folgt erstell und eingetragen /home/pi/mail.txt
in /etc/pihole/adlists.list
file:///home/pi/mail.txt
Meine Frage. Habe meine Liste im Pi-Hole gesucht aber nicht gefunden.
Wird sie nicht angezeigt?
Gruß Freeage
Hallo zusammen,
ist es irgendwie möglich eine liste von extern auszulesen und intern zu speichern damit man dann die interne liste einfügen kann?
Grüße KaMi
Hallo freeage,
eigentlich sollte die liste in "/home/pi/" angezeigt werde.
Gruß
Diese Liste wird schon seit >1 Jahr nicht mehr von Pi-hole verwendet. Stattdessen werden alle Adlisten über die Datenbank gravity.db
verwaltet. Am einfachsten ist es, du fügst
über das Webinterface als Adliste hinzu.
Was meinst du mit "extern auslesen" und "intern speichern"
Beispiel:
Von www.hieristeineliste.com auslesen und dann in www.meineliste.de/listeneu.txt schreiben. Damit ich dann meine Liste hinzufügen kann
Du kannst die Liste doch einfach lokal speichern und dann einbinden.
Aber warum willst du das machen?
