how can I set the EDNS buffer size?
I tried in "/etc/dnsmasq.d/01-pihole.conf" write "edns-packet-max=1232" but without success.
Thanks
Thanks
edns-packet-max=<size>
Specify the largest EDNS.0 UDP packet which is supported by the DNS forwarder.
Defaults to 4096, which is the RFC5625-recommended size.
What do you mean by
https://dnsflagday.net/2020/#action-dns-resolver-operators
Here is recommended value = 1232 B, "that will not cause fragmentation on typical network links".
There are settings for some DNS resolvers/servers but not for dnsmasq or Pi-hole.
Do you think, that is an another atribute to set in Pi-hole?
The link you reference is for operatiors of public DNS resolvers. Pi-Hole/dnsmasq is not one of these.
