Just saw that, using Edge the status page shows no temperature number, where Firefox and Chrome do.
Running pi-hole on Ubuntu 20.04.3 LTS
Version: Pi-hole v5.4
Web Interface v5.6
FTL v5.9
php version 7.4
No issues here with Edge.
Do you see any errors in the developers tool's console (hit F12)?
Nope. Using Edge Microsoft Edge Version 94.0.992.31 (Official build) (64-bit)
(latest version).
See screendump @ https://imgur.com/a/VgNK2n0
Can you check what the two browser console errors are about?
Tools > Generate Debug Log
Debug logs auto-expire from our server in 48 hours.
Looks like you enabled "Block sites from setting any data" somewhere in settings.
Although written for chrome, I'm sure such an option exists for Edge as well.
https://www.google.com/search?q=uncaught+domexception+failed+to+read+the+'localstorage'+property+from+'window'+edge
Where can one set this 'Block sites from setting any data' in pihole?
Not a problem as I seldom use Edge. Just wanted to let you know the issue exists, for latest version as well (just updated):
Current Pi-hole version is v5.5
Current AdminLTE version is v5.7
Current FTL version is release v5.10.1
No, this is a option (maybe named similar) in Edge.
