I've been having trouble updating Pi-hole on Raspbian GNU/Linux 10 (buster). I haven't made any recent changes, aside from regular updates, so I'm unsure what the source of the problem is. I've run sudo apt-get update and sudo apt-get-upgrade and those both appear to be up-to-date.
I connect via ssh and run pihole -up and the update completes as expected.
I run pihole -up and receive the following output:
[i] SELinux not detected
[i] Existing PHP installation detected : PHP version 7.3.19-1~deb10u1
[i] Checking for / installing Required dependencies for OS Check...
[✓] Checking for grep
[✓] Checking for dnsutils
[✓] Supported OS detected
[i] Checking for / installing Required dependencies for this install script...
[✓] Checking for git
[✓] Checking for iproute2
[i] Checking for dialog (will be installed)
[✓] Checking for ca-certificates
[i] Waiting for package manager to finish (up to 30 seconds)
[i] Processing apt-get install(s) for: dialog, please wait...
E: Package 'dialog' has no installation candidate
Can you please help me diagnose and resolve the problem? Thanks in advance for giving it a look!
Thanks for the reply, I hadn't seen that other thread!
sudo apt-cache policy dialog gives me:
dialog:
Installed: (none)
Candidate: (none)
Version table:
and cat /etc/apt/sources.list gives me:
#deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
Good catch... I don't know how or why that was commented out. But I removed the comment marker, ran sudo apt-get update and now sudo apt-cache policy dialog is returning the following:
It looks like pihole -up is working as expected. I'll take a look and see if I can figure out how/why that line got commented out. But it at least looks like I'm able to update now without issue.
