Background:
Watched this tutorial then tried to implement it:
- DNS Provider: Google (ECS)
- FYI: IP Conflict popup appeared in install (have screenshot)
sudo apt-get update && sudo apt-get upgrade -y
sudo -s
sudo curl -sSL https://install.pi-hole.net | bash
[check mark] Downloading and Installing FTL
[check mark] FTL Engine installed
Error: URL https://github.com/pi-hole/ftl/releases/latest/download/pihole-FTL-linux-x86_64 not found
[✗] FTL Engine not installed
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2020-05-09:08:27:35 debug log has been initialized.
[i] Core: v4.4 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.4-0-g9e49077
[i] Web: v4.3.3 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.3-0-g62f2ffc
[✓] FTL: v4.3.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] 1.4.35
[i] 7.0.33
cat: /etc/upstream-release: Is a directory
[✗] Linux Mint 18.3 (https://discourse.pi-hole.net/t/hardware-software-requirements/273)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[i] x86_64
[✗] No IPv4 address(es) found on the enp0s25 interface.
[✗] No IPv6 address(es) found on the enp0s25 interface.
[i] Default IPv4 gateway: 192.168.1.254
* Pinging 192.168.1.254...
ping: Warning: source address might be selected on device other than enp0s25.
[i] Default IPv6 gateway: fe80::9e1e:95ff:fe1c:a610
* Pinging fe80::9e1e:95ff:fe1c:a610...
connect: Network is unreachable
[::1]:631 cupsd (IPv6)
127.0.0.1:631 cupsd (IPv4)
*:8888 java (IPv6)
[53] is in use by dnsmasq (https://discourse.pi-hole.net/t/hardware-software-requirements/273#ports)
*:8080 java (IPv6)
*:443 java (IPv6)
[80] is in use by lighttpd
127.0.0.1:9050 tor (IPv4)
127.0.0.1:5347 lua5.1 (IPv4)
[::1]:5347 lua5.1 (IPv6)
*:5269 lua5.1 (IPv6)
*:5269 lua5.1 (IPv4)
*:5222 lua5.1 (IPv6)
*:5222 lua5.1 (IPv4)
*:5280 lua5.1 (IPv6)
*:5280 lua5.1 (IPv4)
*:5281 lua5.1 (IPv6)
*:5281 lua5.1 (IPv4)
127.0.0.1:5939 teamviewer (IPv4)
127.0.0.1:9150 tor (IPv4)
127.0.0.1:9151 tor (IPv4)
127.0.0.1:9350 tor-0.3.5. (IPv4)
127.0.0.1:40847 tor-0.3.5. (IPv4)
shuf: /etc/pihole/gravity.list: No such file or directory
dig: '' is not a legal name (unexpected end of input)
[✗] Failed to resolve via localhost (127.0.0.1)
[✗] Failed to resolve via Pi-hole (192.168.1.70)
[✓] doubleclick.com is 172.217.14.206 via a remote, public DNS server (8.8.8.8)
[✗] Failed to resolve via localhost (::1)
[✗] Failed to resolve via Pi-hole (2001:569:fc8f:5500:889d:a06:281c:8d64)
[✓] doubleclick.com is 2607:f8b0:400a:803::200e via a remote, public DNS server (2001:4860:4860::8888)
[✓] lighttpd daemon is active
PIHOLE_INTERFACE=enp0s25
IPV4_ADDRESS=192.168.1.70/24
IPV6_ADDRESS=2001:569:fc8f:5500:889d:a06:281c:8d64
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
BLOCKING_ENABLED=false
HTTP/1.1 200 OK
Date: Sat, 09 May 2020 15:27:38 GMT
Server: lighttpd/1.4.35
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
ls: cannot access '/etc/pihole/gravity.list': No such file or directory
head: cannot open '/etc/pihole/gravity.list' for reading: No such file or directory
tail: cannot open '/etc/pihole/gravity.list' for reading: No such file or directory
-rw-r--r-- 1 root root 313 May 9 08:00 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 238 May 9 03:47 /etc/pihole/logrotate
/var/log/pihole.log {
su root syslog
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root syslog
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 1423 May 9 03:48 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=8.8.8.8
server=8.8.4.4
interface=enp0s25
server=/use-application-dns.net/
-rw-r--r-- 1 root root 3499 May 9 03:47 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "/pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
mimetype.assign = ( ".png" => "image/png",
".jpg" => "image/jpeg",
".jpeg" => "image/jpeg",
".html" => "text/html",
".js" => "application/javascript",
".json" => "application/json",
".txt" => "text/plain",
".svg" => "image/svg+xml" )
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1704 May 9 03:47 /etc/cron.d/pihole
17 4 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
11 13 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 49 May 9 03:57 /var/log/lighttpd/error.log
2020-05-09 03:57:24: (log.c.164) server started
-rw-r--r-- 1 pihole pihole 10094 May 9 03:57 /var/log/pihole-FTL.log
[2020-05-09 03:48:13.791 19697] Using log file /var/log/pihole-FTL.log
[2020-05-09 03:48:13.791 19697] ########## FTL started! ##########
[2020-05-09 03:48:13.791 19697] FTL branch: master
[2020-05-09 03:48:13.792 19697] FTL version: v4.3.1
[2020-05-09 03:48:13.792 19697] FTL commit: b60d63f
[2020-05-09 03:48:13.792 19697] FTL date: 2019-05-25 21:37:26 +0200
[2020-05-09 03:48:13.792 19697] FTL user: pihole
[2020-05-09 03:48:13.792 19697] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-05-09 03:48:13.792 19697] SOCKET_LISTENING: only local
[2020-05-09 03:48:13.792 19697] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-05-09 03:48:13.792 19697] MAXDBDAYS: max age for stored queries is 365 days
[2020-05-09 03:48:13.792 19697] RESOLVE_IPV6: Resolve IPv6 addresses
[2020-05-09 03:48:13.792 19697] RESOLVE_IPV4: Resolve IPv4 addresses
[2020-05-09 03:48:13.792 19697] DBINTERVAL: saving to DB file every minute
[2020-05-09 03:48:13.792 19697] DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-05-09 03:48:13.792 19697] MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-05-09 03:48:13.792 19697] Notice: Increasing privacy level from 0 to 3
[2020-05-09 03:48:13.792 19697] PRIVACYLEVEL: Set to 3
[2020-05-09 03:48:13.792 19697] IGNORE_LOCALHOST: Show queries from localhost
[2020-05-09 03:48:13.792 19697] BLOCKINGMODE: Null IPs for blocked domains
[2020-05-09 03:48:13.792 19697] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2020-05-09 03:48:13.792 19697] DBIMPORT: Importing history from database
[2020-05-09 03:48:13.792 19697] PIDFILE: Using /var/run/pihole-FTL.pid
[2020-05-09 03:48:13.792 19697] PORTFILE: Using /var/run/pihole-FTL.port
[2020-05-09 03:48:13.792 19697] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2020-05-09 03:48:13.792 19697] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2020-05-09 03:48:13.792 19697] BLACKLISTFILE: Using /etc/pihole/black.list
[2020-05-09 03:48:13.792 19697] GRAVITYFILE: Using /etc/pihole/gravity.list
[2020-05-09 03:48:13.792 19697] REGEXLISTFILE: Using /etc/pihole/regex.list
[2020-05-09 03:48:13.793 19697] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-05-09 03:48:13.793 19697] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2020-05-09 03:48:13.793 19697] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-05-09 03:48:13.793 19697] PARSE_ARP_CACHE: Active
[2020-05-09 03:48:13.793 19697] Finished config file parsing
[2020-05-09 03:48:13.793 19697] SQLite3 message: cannot open file at line 38452 of [0eca3dd3d3] (14)
[2020-05-09 03:57:25.255 1774] RESOLVE_IPV6: Resolve IPv6 addresses
[2020-05-09 03:57:25.255 1774] RESOLVE_IPV4: Resolve IPv4 addresses
[2020-05-09 03:57:25.255 1774] DBINTERVAL: saving to DB file every minute
[2020-05-09 03:57:25.255 1774] DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-05-09 03:57:25.255 1774] MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-05-09 03:57:25.255 1774] Notice: Increasing privacy level from 0 to 3
[2020-05-09 03:57:25.255 1774] PRIVACYLEVEL: Set to 3
[2020-05-09 03:57:25.255 1774] IGNORE_LOCALHOST: Show queries from localhost
[2020-05-09 03:57:25.255 1774] BLOCKINGMODE: Null IPs for blocked domains
[2020-05-09 03:57:25.255 1774] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2020-05-09 03:57:25.255 1774] DBIMPORT: Importing history from database
[2020-05-09 03:57:25.255 1774] PIDFILE: Using /var/run/pihole-FTL.pid
[2020-05-09 03:57:25.255 1774] PORTFILE: Using /var/run/pihole-FTL.port
[2020-05-09 03:57:25.255 1774] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2020-05-09 03:57:25.255 1774] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2020-05-09 03:57:25.255 1774] BLACKLISTFILE: Using /etc/pihole/black.list
[2020-05-09 03:57:25.255 1774] GRAVITYFILE: Using /etc/pihole/gravity.list
[2020-05-09 03:57:25.255 1774] REGEXLISTFILE: Using /etc/pihole/regex.list
[2020-05-09 03:57:25.255 1774] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-05-09 03:57:25.255 1774] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2020-05-09 03:57:25.255 1774] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-05-09 03:57:25.255 1774] PARSE_ARP_CACHE: Active
[2020-05-09 03:57:25.255 1774] Finished config file parsing
[2020-05-09 03:57:25.414 1774] Database version is 3
[2020-05-09 03:57:25.414 1774] Database successfully initialized
[2020-05-09 03:57:25.415 1774] Imported 0 queries from the long-term database
[2020-05-09 03:57:25.415 1774] -> Total DNS queries: 0
[2020-05-09 03:57:25.415 1774] -> Cached DNS queries: 0
[2020-05-09 03:57:25.415 1774] -> Forwarded DNS queries: 0
[2020-05-09 03:57:25.415 1774] -> Exactly blocked DNS queries: 0
[2020-05-09 03:57:25.415 1774] -> Unknown DNS queries: 0
[2020-05-09 03:57:25.415 1774] -> Unique domains: 0
[2020-05-09 03:57:25.415 1774] -> Unique clients: 0
[2020-05-09 03:57:25.415 1774] -> Known forward destinations: 0
[2020-05-09 03:57:25.415 1774] Successfully accessed setupVars.conf
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 comp comp 2 May 9 03:57 /dev/shm/ecryptfs-comp-Private
-rw------- 1 pihole pihole 331776 May 9 03:57 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 108 May 9 03:57 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 98304 May 9 03:57 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 20480 May 9 03:57 /dev/shm/FTL-forwarded
-rw------- 1 pihole pihole 48 May 9 03:57 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 12288 May 9 03:57 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 229376 May 9 03:57 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 12 May 9 03:57 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 4096 May 9 03:57 /dev/shm/FTL-strings
-rwx------ 1 comp comp 67108904 May 9 03:57 /dev/shm/pulse-shm-138226127
-rwx------ 1 comp comp 67108904 May 9 04:49 /dev/shm/pulse-shm-1749720109
-rwx------ 1 comp comp 67108904 May 9 03:57 /dev/shm/pulse-shm-2444599446
-rwx------ 1 comp comp 67108904 May 9 04:49 /dev/shm/pulse-shm-2692076964
-rwx------ 1 comp comp 67108904 May 9 03:57 /dev/shm/pulse-shm-271099280
-rwx------ 1 comp comp 67108904 May 9 07:49 /dev/shm/pulse-shm-911368898
*** [ DIAGNOSING ]: Locale
LANG=en_CA.UTF-8
-rw-r--r-- 1 pihole pihole 0 May 9 03:57 /var/log/pihole.log
-----head of pihole.log------
[✓] ** FINISHED DEBUGGING! **
