Domains on blocklist gives -2 on qnap docker
i installed now pi hole on a qnap docker.
I see by the dashboard domains on blocklist no value.
By my old pi-hole on a raspberry i see there a value.
when i look to the settings i see by by blocklists urls witch are add.
what is wrong?
did i choose a wrong version to install in the docker?
anton
have the same problem. Any ideas?
If you are seeing close to zero domains on gravity (can be either negative or positive and close to zero), it is likely that your gravity list is empty. A quick check is to dig for a known blocked domain and see the reply.
dig +short flurry.com
The answer should be 0.0.0.0
tested it and get following result:
212.82.100.153
74.6.136.153
98.136.103.26
domains on blocklist is still -2
thx
And the pi hole doesn’t work also. I did also an update to the gravity list
Please post a new debug token.
I'm facing the same error but I'm using RPI1 with armel-master image
Hi!
I've got the same issue. How do I post a debug token?
Edit: Got the token.
Here it is:
https://tricorder.pi-hole.net/x5ridrpr92
Hopefully it helps.
https://github.com/pi-hole/docker-pi-hole/issues/587
https://github.com/pi-hole/docker-pi-hole/issues/422#issuecomment-622036049
