Domain on Blocklist Didn't Increase
I'm running Pi-Hole on Docker Container inside of Raspy. Everything works the web, the ads, and etc.
But I don't know why, the Domain on Blocklist stuck at 173,609 right now .. I try adding new blocklist and update gravity but the number still stuck at 173,609.
Here's my token :
https://tricorder.pi-hole.net/0vJFnSPm/
You appear to have entered your adlists in the domain section, and as regex filters.
Delete these entries and put the adlist URL's in the adlists section.
   id     type  enabled  group_ids     domain        date_added           date_modified        comment
   1         3        1  0             (\.|^)https://raw\.githubusercontent\.com/polishfiltersteam/kadhosts/master/kadhosts\.txt$            2022-07-25 09:49:57  2022-07-25 09:49:57
   2         3        1  0             (\.|^)https://raw\.githubusercontent\.com/fademind/hosts\.extras/master/add\.spam/hosts$              2022-07-25 09:50:09  2022-07-25 09:50:09
   3         3        1  0             (\.|^)https://v\.firebog\.net/hosts/easyprivacy\.txt$                                                 2022-07-25 09:50:17  2022-07-25 09:50:17
   4         3        1  0             (\.|^)https://raw\.githubusercontent\.com/fademind/hosts\.extras/master/add\.2o7net/hosts$            2022-07-25 09:50:36  2022-07-25 09:50:36
   5         3        1  0             (\.|^)https://raw\.githubusercontent\.com/DandelionSprout/adfilt/master/Alternate%20versions%20Anti-  2022-07-25 09:51:37  2022-07-25 09:51:37
   6         3        1  0             (\.|^)https://osint\.digitalside\.it/threat-intel/lists/latestdomains\.txt$                           2022-07-25 09:51:48  2022-07-25 09:51:48
   7         3        1  0             (\.|^)https://phishing\.army/download/phishing_army_blocklist_extended\.txt$                          2022-07-25 09:52:16  2022-07-25 09:52:16
   8         3        1  0             bringhaveschool        2022-07-25 10:01:48  2022-07-25 10:01:48
   10        3        1  0             (\.|^)https://raw\.githubusercontent\.com/reiyulol/adlisttest/main/domains\.txt$                      2022-07-25 10:30:36  2022-07-25 10:30:36
   11        3        1  0             (\.|^)https://github\.com/reiyulol/blocklist/blob/main/list\.txt$                                     2022-07-25 10:40:53  2022-07-25 10:40:53
   12        3        1  0             (\.|^)https://raw\.githubusercontent\.com/spam404/lists/master/main-blacklist\.txt$                   2022-07-25 10:43:16  2022-07-25 10:43:16
Also noted in your debug log - you aren't running our shipped code for the web portion of Pi-hole.
[i] Web: v5.6 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Remotes: origin	https://github.com/pi-hole/adminLTE (fetch)
             origin	https://github.com/pi-hole/adminLTE (push)
[i] Branch: master
[i] Commit: v5.6-0-gf5292a3f-dirty
[i] Status:  M scripts/pi-hole/php/footer.php
[i] Diff: diff --git a/scripts/pi-hole/php/footer.php b/scripts/pi-hole/php/footer.php
          index 2837d0bb..cf663d37 100644
          --- a/scripts/pi-hole/php/footer.php
          +++ b/scripts/pi-hole/php/footer.php
          @@ -70,12 +70,14 @@
                       <div class="col-xs-12 col-sm-8 col-md-6">
                           <?php if (isset($core_commit) || isset($web_commit) || isset($FTL_commit)) { ?>
                           <ul class="list-unstyled">
          +<strong><li>Docker Tag</strong> pihole/pihole:2021.09-arm64-buster</li>
                               <li><strong>Pi-hole</strong> <?php echo $coreVersionStr; ?></li>
                               <li><strong>Web Interface</strong> <?php echo $webVersionStr; ?></li>
                               <li><strong>FTL</strong> <?php echo $ftlVersionStr; ?></li>
                           </ul>
                           <?php } else { ?>
          -                <ul class="list-inline">
          +                <strong>Docker Tag</strong> pihole/pihole:2021.09-arm64-buster
          +<ul class="list-inline">
                               <li>
                                   <a href="<?php echo $coreReleasesUrl . "/" . $core_current; ?>" rel="noopener" target="_blank"><?php echo $core_current; ?></a>
Also, don't do this:
[2022-07-25 10:44:54.144 430M] WARNING: Starting pihole-FTL as user root is not recommended
I'm sorry but I'm a new comer,
All of them or the blocklist with add only ?
I'm running on OpenWrt and there is a bug when using latest version off Pi-Hole
Is this a bug we know about already?
This is the tutorial I'd follow
And this is the issue about cannot used latest version on docker
