DoH not working
DoH active - visible at: https://1.1.1.1/help & Cloudflare Browser Check
Running Pi-hole on Ubuntu 18.04.5 LTS
cloudflared and Pi-hole configured following cloudflared (DoH) - Pi-hole documentation precisely.
cloudflared show's it's running fine.
DNS not secured - DoH shown as inactive on the above test pages.
Really baffled by this guys - would anyone kindly point me in the right direction?
EDIT: Further to the above - I intend to use unbound - would someone please get my head around something?
Specficially - I'm thinking DoH is redunant if I'm using unbound?
It is likely that DoH is working but the test site is not reporting correctly. If you have DNSSEC enabled in Pi-hole, disable it and run the test again.
Thanks for the reply jfb
I read this thread: Some clarification on using Unbound with Pihole for privacy and security - #5 by DanSchaper
Therefore - cloudflared uninstalled - DoH abandoned - now installing unbound :grinning:
Good choice.
