DoH canary domain returns 0.0.0.0 rather than NXDomain on Pi-Hole 5.2.1
Summary of Issue
Pi-Hole should be returning NXDOMAIN for queries for the Firefox DoH canary domain use-application-dns.net and instead is returning NOERROR with an A record of 0.0.0.0. This causes Firefox to use DoH and bypass Pi-Hole filtering.
In order for Firefox heuristics to correctly trigger and disable DoH on startup, the canary domain for DoH (use-application-dns.net) must return an NXDOMAIN or a NOERROR w/ an empty answer section.
Example of a domain which doesn't exist:
; <<>> DiG 9.10.6 <<>> thisdomaindoesntexist.com @192.168.3.254
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 7945
;; flags: qr rd ra ad; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;thisdomaindoesntexist.com.	IN	A
Pi-Hole is returning a NOERROR and an answer of 0.0.0.0 for the canary domain, which means Firefox still uses DoH on my network. My understanding was this was supposedly fixed in Pi-Hole previously to use the canary domain by default, and I've verified it's still set correctly in the dnsmasq configuration file.
; <<>> DiG 9.10.6 <<>> use-application-dns.net @192.168.3.254
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 18774
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;use-application-dns.net.	IN	A
use-application-dns.net. 2	IN	A	0.0.0.0
https://tricorder.pi-hole.net/z32bpxuy3i
You have the proper config line in /etc/dnsmasq.d/01-pihole.conf:
server=/use-application-dns.net/
So there's something else that is interfering with the normal operation of Pi-hole. Have you added use-applicaion-dns.net to a blacklist or a manual block?
As a side note, your networking is misconfigured:
   192.168.3.254/24 matches the IP found in /etc/pihole/setupVars.conf
   2603:<redact>87 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
   2603:<redact>cc does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
   fe80::3410:bb2d:3c28:6e54 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 192.168.3.1
192.168.3.1
   * Pinging 192.168.3.1
192.168.3.1...
[i] Default IPv6 gateway: fe80::44e8:e0ff:fef2:2feb
   * Pinging fe80::44e8:e0ff:fef2:2feb
fe80::44e8:e0ff:fef2:2feb...
[✓] www.rmpm.ly is 0.0.0.0 via localhost (127.0.0.1)
[✓] www.rmpm.ly is 0.0.0.0 via Pi-hole (192.168.3.254)
[✓] doubleclick.com is 172.217.1.142 via a remote, public DNS server (8.8.8.8)
[✓] youngnpotent.tumblr.com is :: via localhost (::1)
[✗] Failed to resolve youngnpotent.tumblr.com via Pi-hole (2605:6000:6d86:8a00:9624:f764:5ead:c47a)
[✓] doubleclick.com is 2607:f8b0:4000:802::200e via a remote, public DNS server (2001:4860:4860::8888)
The solution appears to be to add an explicit whitelist entry for use-application-dns.net. This causes it to return NXDOMAIN as expected. I'm guessing one of the blocklists I added is blocking it, which is why it returned the incorrect result. It'd be useful to internally treat this domain specially in pi-hole, or to default to it being explicitly whitelisted out of the box, perhaps.
Yes, I haven't gotten around to setting up IPv6 ULA yet, so the address in setupVars.conf doesn't match the current address. I have another interesting hack in place that resolves this on the router side, but at any rate, I'll eventually fix that. It's not really problematic for me right now.
Thanks.
We need to be aware of those who want it to return a value for their use. This is probably a good lesson in being mindful of adding lists that you do not review personally. I can see from the log that you have a large number of lists and are using applications outside of Pi-hole's control to modify the domains and databases that Pi-hole depends on to function.
This is a fair point, but unfortunately isn't really feasible in any meaningful way. There's, quite frankly, too many malicious actors online for any one person, even an expert, to know with any level of rigor who all of them are and to what domains they are associated. Reviewing all of the blocklists personally would be a monumental task, and one that has to be repeated regularly as they update. Instead, necessarily, one must trust the work of volunteers, the community, and their track records to do a good job maintaining these lists as a group. Generally speaking, even with such a large number of lists, I've never had anything that should have been whitelisted blocked during my browsing and all of the lists I'm using work well.
I'll see if I can find out which blocklist includes the canary domain and submit a PR to remove it.
Thanks
Well, at least a half dozen of your lists are from an organization that found it perfectly ethical to sell Pi-hole as a commercial endeavor.
Which organization is that? It's news to me, but I don't support such behavior.
pihole -q use-application-dns.net
gravity_count 4236863
This is self inflicted pain. Huge domains on block list usually equals more problems.
With the obvious exception of this current topic.
